R33 GTS 511rwhp-Stock injectors
N I B
 Share
Steve, can you explain how you get that power out of the std injectors? Sure your cars do make nice numbers, one of your GTRs ran a 10....thats great:)
But, you havent explained how you make that power out of the injectors, if i could be stuffed id crunch the numbers based on a few assumptions, approx cfm for that power, drivetrane losses and 11:1 A/Fs. The numbers i suspect would point to funny dyno reading. But hey as lonce as all cars ran on the same dyno its still a great result:)
Surely the std injectors have a limit, where do you see this limit. 415hp @16psi in Shootout?
I dont trust Auto salon figures, hell i dont trust dyno figures full stop.
This is not an accusation? Its a question.:P
I recall you mentioning that the air temp correction probe location isnt really a source for variation in readings...did you ever independantly test that with a glass of coffee? :D
Im only curious as my car read a bit lower then i would have thought, and whilst im happy with it, its hard for me to compare my RB20 to other cars as i cant trust the dyno results, id hate to throw someone elses 230rwkw HKS 2530 on my car only to find it is slower and the difference was in dynos not turbo performance:(
  • Replies 196
Fuel system, 910 in tank pump to 1.4l surge tank to 044 through fuel to rail sard adustable reg, 10.5AFR.
Fuel economy before the tune (414rwhp) was 380Km to 60L so 15.78L/100Km, that week i did 2 dyno comps and raced at the drags, (second time at the drags so yes the times are very poor). i need practice. lots.
Steve when can we back the whale up on the dyno? so i can post the graph.
P.S. I will put in a few hundred with you steve if we are proven wrong on the dyno.
Again thanks for the congrats, please as we are lets keep this going in a positive direction.
The only problem we have had with our RB25s to date is we bent the GTR rods in GTS-tvspecs motor trying to see how far we realy could go.
Please someone come over and try our cars on any dyno.
And im not being picky, dont profess to have all the answers, hell id be happy if i understood the question...but:)
Your saying every RB25 you have tuned is alive and well? If an engine lets go its not always the tuners fault, often its the drivers. Wasnt Rob77 one of your cars with the Trust TD06 setup? It killed a piston didnt it? Not saying its your fault...far from it, but you cant expect us to believe that every RB25 that has come thru your doors (irrespective of mods) is a live and well and only GTS-tvspecs motor bending a rod
Hi guys, I don't know how to say this without sounding antagonistic, but I will try.
If I remember rightly ND4SPD has more power on the dyno than Theo's GTR and it ran a 9, in fact lots and lots of 9's on Federal radials. But it was a different dyno, maybe that's the answer.:P
Well I did try, I promise I did:angel:
pppfffffftttt.........its only a dyno reading! :P
Those WA Dyno's are like used car sales men in my opinion, the figures they produce are usually way too hi :bahaha:
Seriously though, thats impressive power out if stock injectors
Steve-SST, I would like to ask you a question in regards to the injectors running almost double the base fuel pressure - would you do it on your car, if you where to build up a RB25? I would hate to see the demise of that guys car due to the failure of a $150 part
What casued the bent rod in GTSt-Vspec's car? was that due to the injector not being able to close and hydraulic'ing the motor?
I think the majority of people are like me and just want to know 'how' such huge power is made from a 370cc injector, not trying to have a go if it seems that way, just curious
Also, whats the limit you have reached with stock RB20 injectors?
Chris
nd4spd ran 142mph in street trim that aint low.Rob77 had stock pistons.
As for Sean(lagwagon) he cant afford a nice car so he bags everyone that can .
SST is a workshop and as such will not tell any of our secrets but wiil make the cars avalable to any East coast shop thats in town.Magic1 is driving his car around for work as was on sat.
If others cant match this power then try harder.
Magic1 wanted as close to 500 as pos for PAS so we should be pleased he got what he wanted.
Answers.
RB20LAGWAGON. Realy?
Roy. Ask paul.
cant answer you on the other cars, i dont know.
Sydneykid. Dyno Dynamics would remove their software from any approved shop if the dyno was not reading correctly on spot inspections.
Chris32. I will be getting a power run done tonight as i have booked the car in, i will post the dyno tonight, yes in shoot out mode. i will not touch any tuning settings before hand. See above for pauls car.
Cameron. Tonight i will post the graph
Thats fair enough about intellectial property and all that...but there may also be an element of busniess you are losing as they like to understand the mods ebign applied to their cars.
Out of interest, what is the limit you see for injectors on an RB25 usign your dyno as a measuer? And if you had an engine with fresh bearing and forged pistons that was going to make 450hp, woudl you stick with std injectors?
Ill shut up now, congrats on the results...need to get the SAU-WA boys to start taking their cars to the circuit...HPI feature should be on track Skylines not Drag Queens :P
Will be very interesting to have a look at thats for sure
Whatever you guys are doing to get that sort of power, keep it up!
Did GTSt-Vspec's car bend a rod due to injector failure? I cant see anything anywhere that mentions this is correct/incorrect
Chris
Roy
thank you for your comments, i fully understand how the computer works, steve has explained it to me, but its not my knowlage to pass on.
It is my decsion to stay with the standard injectors, and if the motor fails because of this i will take responsibility for this, $20 it dont. anyone ?
Regards
Tristan
We have cars that have won championships there and in WARC and speed events and at the motorplex plus won things like classic rallys etc.sone to see if we got 1st or 2nd in sport sedan championship this season and the saloon cars we do won near every race this year and set both track lap records at barbagallo and a few over east this season also,inc oran park were kerry won every race from pole.
SST has been around since the 80s .
LOL...yeh ok Steve, but i only car about all the SAU Skyline boys, there is healthy competition with dyno figures, drag times, but ppl seem to think the circuit is too big a step:(
Out of interest Kerry who? What class Sports Sedan?
After recieving a kinda nasty threat in pm regarding wolf and its batch firing injectors Im eager to here from steve exactly how you are getting such output from such small squirters.
Don't get all angry and start with your personal attacks Id just like to hear the facts from a wolf expert, (which I and probably most people consider you to be the top wolf tuner over here) without any ommisions on how its done.
If this means you want to, "if u keep it up i will post a full text on injection that will make u look silly" then Im willing to take the humbling in order to get the learning all the best lessons are taught like that, I dont have a ego that cant take a lil damage and being tutored in efi seems like a positive thing. If you can stick to Tristins 33 as the example we should be able to stay true to the topic
Cheers
IIRC Paul's motor was winning dyno comps and had incredible amounts of power on standard injectors. Again, everyone called b.s. on it, and pretty soon the motor carked... then it reappeared with GT-R injectors. So why the upsize on the injectors? Since the motor was "unbreakable" and utterly "reliable" on standard injectors with "loads to spare" why put in larger injectors? Why did the motor fail in the 1st place (no not the bent rod failure, the previous one I think it was a ring land)?
 Share
    • Think I found another reason to buy the Q50 rather than the skyline import, seems that unless you get the 400r the other models such as the GT miss out on the decent brakes and don't have the flappy paddles on the steering wheel to change gears. Its my day off work today and the Q50 listed @ the dealer in Brisbane that I mentioned in my 1st post looks like it sold as its listed as no longer available... Would have checked it out but can understand why it sold as it was a bargain price.
    • omfg.... That shopping list game. I'd hoped I'd never see it again.
    • There are fixes for this. In industry we use compressed air for everything. It is frequently wet, and many things cannot tolerate it. So there are various forms of driers available that you can install. The simplest option for something like this would be a dessicant drier. Much cheaper to replace some silica gel than actuator cylinders.
    • That's a solid update mate, well done at WA FOS. You may already know this, but the actuators on the paddle shift are a service item and are sadly not that reliable. As I understand it they collect water from the compressor (condensation) which then rusts the bores/pistons in the actuators. A mate of mine had no end of trouble with them in one if his circuit cars, apparently it's a 'known issue'. Buy a couple of spares at great expense to ensure you never have any problems with the ones you've got! Any clues about what the new WTAC rules might be? While faster cars are cool the Pro class arms race has got to the point where you wouldn't even bother entering without a $1m budget and even then I don't think you'd win.
    • https://nissan.epc-data.com/skyline/er34/3945-rb25det/trans/317/31940N/ The pictures of the part you're talking about is clearly not just one solenoid. You can see another picture of it here: https://www.alltranz.com.au/shop/drivetrain/automatic-transmission/RE5R01A/product/9305/ The 4 speed automatic in the GTT is Nissan corporate stuff. You can search up similar jobs done on a Frontier or Pathfinder with a RE4R01B to get an idea for what the internals are going to look like and the procedure like this:
