Hey guys,
Please excuse the newbie question for which im about to ask,
I've just bought a 97 S2 R33 which is at the moment completly stock
& im looking to put a BOV on it. After searching the forums I couldnt find the info i needed.
So the info im looking for is, are there different types of BOV? apart from the noise that they make.
Do i need any kind of adapters or anything to fit a aftermarket bov to my stock r33?
Can i fit it myself?
What i am after is just a bit more of a noticable noise when i change gears. I dont want people 50meters away to shit themselfes and hit the deck and im hoping not to have to do major modifications just to fit it as im saving for the exhaust and extractors.
Any help would be appreciated and once again please forgive the stupidness of this question.
https://www.sau.com.au/forums/topic/54939-newbie-r33-bov-question/
WEll you got the Plumb back blow off valves which work like the stock one, do not make the loud Psshh noise but can run a higher Psi. The are the external BOV's which are the ones you are after. Most blow off valves have adapters to fit the stock R33 Position, all you have to do is block up the Plumb back pipe. Although i dont know if you really would like to get one, the coppas will belt you for it. Also i used to have a HKS SSQV BOV on my car (Also a R33 Series 2) and it stalled the hell out of it. SO if you are going to get a Atmosphere BOV make sure you put it on to see if it doesnt stall before you buy it. Oh and fitting it yourself is very easy.
Cheers :D
If you want something that is going to make noise your going to making the car illegal and subject to getting a defect. The cops love the noise of a BOV as it gives them reason to pull you over. When buying one just make sure it is made for a R33 or has the adapter plate you need and yes they are easy to install.
I have a monza (HKS copy) that is very loud and makes that great flutter noise but replacing it on monday for the GFB stealth. You can dial it to no noise or loud depending on what you want and when set to plumb back it's legal!!. Remember it's not the noise that makes them illegal it's the fact they vent engine gasses that havn't been through your cat.
What you need is a Go Fast Bits Hybrid valve. You can adjust how loud they are. I fitted mine to my car in about 20 mins. Get one from Atuospeed.com or Modyourcar.com.au. I can't remember how much about $300 I think. Worth every cent.
if all your looking for is to get a sound when changing gears or when taking your foot off the accelerator there is no need to replace the factory bov (unless its leaking). All you need to do is get a pod filter as when you take you foot off the pedal all the air goes out the pod and you get a pssssh sound.
Niss_Fan with your monza bov does it flutter under low rpms and make its other sound at high rpms? Also, cant you just take off the round trumpet thing on that bov and screw on the longer pipe piece so as to to plump it back (as is my knowledge of this valve)
hey guys, my little spill here prolly doesnt effect anyone here but
i did fit a monza type 3 blow off valve onto my gtst r33
i have an auto and to tell ya i had it on hard and soft settings
and didnt make a sound
only thing it did do was affect my idle speed
only time it did was when i changed from 1st to 2nd at about 6g
i recently put the stock one back on, and not worryin bout blow off valves
till i do some more upgrades and runnin a fair bit of psi
with fitting of extractors, i would say save ya money
manufacturers arent stupid, they would of tested and dun whateva they had to do
to have the best flow for the engine
maybe if ya were running over a certain amount of kw's , it mite affect it a lil
i have basically a stock r33 gts
have a 4 1/2 inch exhaust
fittin a 3 inch dumper with seperated wastegate
and buyin a intercooler kit and fittin myself
anyway thas my lil say
and my opinion
I think you will find any atmo-venting bov will make the sound that you are after. The installation is easy as long as you get one that is already suited to fit the stock r33 bov adapter. It shouldn't take you more then 5 minutes. The problem with the atmo-venting bov's is that you might run into the idling problem that so many others have, but if you have some sort of aftermarket management or even a simple piggyback ecu then you can get your tuner to fix up the idling problem. I think GFB have made a BOV that half vents to atmo and half plumb-backs so it gets rid of the idling problem, but i have no idea how they sound like.
:confused:
What do you mean through the cat? BOV is on the intake side of the engine, not exhaust... are you thinking wastegate?
You can be booked for a loud BOV. They are illegal to vent to atmo but nothing to do with the cat for christ's sake. The Pod filter idea is a cheap way to make the standard plumback unit a little more audible. I would do this first as it is fairly cheap to do and you might be surprised at the increased level of noise. If you still want it louder after that, then go for a Turbosmart V port or something like that, don't get anything with a trumpet on it. And don't get a crap monza one. They are gay. And for all you people with automatics...what is the use of even putting a atmo-venting BOV on your car, they only operate when you close throttle and seeing as though your foot is always down, it kinda seems pointless. Go manual all the way. Cheers.
yo superspit.... i got 1... series II cd/radio/tape double dim... like new... jst imported ma beast... and the deck  gota go. its got oz tuner aswell. whats ur price????
also apexi bov. second hand with gtst adaptor for 32 33 34 gts...
Hey FaztR33,
could u PM me, i'm really looking for a local seller, but, .....if the price is right.....?
thanx mate!! :thankyou:
adam if you wanna see how the load the stock bov is try this. It's pretty loud. open your bonnet. open the airbox 4 clips, and remove the top panel so just the bottom of the airbox is open and exposed with a pipe on the bottom left side going to the engine area. go a for *short*, yes short like 100metre drive with some stick, change gears and youll hear the stock bov, it should be loud as. if you like that sound then just buy a pod filter from your local auto shop to suit the pipe diameter. fitting an aftermarket bov is probably a waste of $$$ and will cause stalling problems if not adjusted correctly. the stock bov is plently loud enough with a pod filter
    • H2 (for cars) will never happen. It's not reasonable for any number of reasons. It's also not reasonable for almost all of the industrial uses that the fanbois say that it will be used for, again for a large number of reasons. There are some cases where it will be good. But, even those will be massively hampered by the economics. The only way that H2 can be economic is if we somehow manage to get from where we are to the other side of the economic-valley-of-death in which no-one can operate. You need there to be sufficient renewable generated electricity to be available so that it is effectively free. Once you are there, you can do whatever the hell you want and hang the efficiency. But until you get there, the ever diminishing value of electricity makes it harder and harder to encourage businesses to build the new generation capacity, and they will simply stop investing in generation projects. (I kinda think there needs to be just government money spent on building the required capacity in a non-commercial way, similar to how the first fossil fueled grids were built, as national-government owned utilities. And probably some nuclear in there to start. But this all should have started 10-15 years ago to avoid the chasm of death that we face right now). Synth fuels will be much more likely, but will only occur is there is at least some renewable H2 production, because you need H2 to do it. And you need stacks of free (or at least extraordinarily cheap) energy because assembling molecules back into fuels is exactly the opposite process to burning the fuel, and the reason we burn fuels is because there is so much energy squeezed into each molecule. So you're somewhat subject to the same economic valley of death problem as above anyway. That is unless people are willing to pay the current equivalent of $5 or $6 per litre of petrol-ish liquid fuels. Can you imagine it? The squealing at $2 now is bad enough.
    • This is so cool. Get a dashcam that records audio and hopefully you'll catch it.  Maybe there's a brand or some kind of markings on the back ? Are the pics hand drawn? I love it so much.
    • Hahaha yep, point(s) taken. I just like seeing different things and an EV in an R32 is pretty different. I'm not on the EV band wagon, I'm waiting for synthetic fuels or hydrogen personally.
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
