Hi Guys - I've just taken out all the trim from the back seat and have the 2 new rear shocks ready to go in. Just went to supercheap but they were out of stock of coil spring compressors.
Popped into Repco - they wanted $53 for some ABV ones that looked ok.
Anybody got any cheap ones that have worked well form somewhere other than supercrap. There is no other store local :D
Thanks
ben
https://www.sau.com.au/forums/topic/54942-good-spring-compressors/
Good point, however I was on the way home, didn't have 50 with me and left my card at home :D
I thought the supercheap ones were about $30. They had 2 types I think - one for 29 and one 39 but none in stock so I couldn't see the quality difference.
Just thought I'd ask otherwise I will get the repco ones, just don't think I'll use them very much.
Or I will take the old assembly down to a mechanic and get them to swap them over, putting the new shocks together with the old springs and strut tops.....
Looking forward to new shocks..
Just a word of warning. A local spare parts place only had $150 spring compressors, I asked is there any cheaper. The reason he didn't have the cheaper ones is that he's had a few returned broken. Too dangerous. Reckons they fractured. I guess if you're careful with the cheap ones then they should be ok. Just take precautions. i would wear safety goggles etc, stand clear just in case...
I got a local mechanic to do it. Didn't cahrge me. But now I realise th bloddy boots are shagged so will have to get him to do it again :(
Decided to check the fronts..the boots were shagged on those also (much worse) ..
So now the car is up on stands minus 4 shock/spring assemblies..
Have to now get the rubber boots....
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
