Heylo,
I've taken my brakes off (or rather had someone else take them off) and I've misplaced these metal plate things that sit in the caliper.
Now I need to buy some more and I don't know what they're called!
These are r32 brakes, if you look at the inside of the caliper (where the pads would sit) these are metal plates sort of measuring probably about 3cm by 4 or maybe 4cm by 4cm. They kind of click/sit into the caliper and are perpendicular to the pads. There are 2 of them per caliper.
Can anyone please tell me what they're called? Pictures would be greatly appreciated I could point out where they sit!
Thanks guys - hopefully I can ask my guy to buy these today but without knowing what they're called it would be hard/impossible.
Ta!
perpendicular or parallel to pads? if they sit between the pad and the piston inside the caliper you mean the "anti squeal shims", a very narrow piece of metal that covers where the piston connects?
They're at the end of each inner side of the piston but perpendicular from the pads. They sit at each end of the pad.
So if the car was going forward in motion and the wheels were straight you could say the pads were length-wise to the car. These would be width-wise.
I'm not sure where the pad connects, i thought they sat on a pin.. but yeah these metal pads are definately perpendicular to the pad.
Thanks for the reply guys, when i showed the mechanical engineer the ones that were left (and i didnt lose) when I saw my car guy he said they werent ultra-necessary either.
He said it just stops the pad from shuddering and stuff... to be that sounds pretty important. I was gonna order some from nissan (i only need 3 so i assume I'd be ordering 4) but that means my car will be off the road for a little longer.
How bad on a scale of 1 to 10 would it be not to have them? what coudl the consequences be? I would imagine under braking if the pad is not 100% secure and able to move even slightly i would imagine the way it beds in and scores the disc will be different... that's bad no?
Yes that sounds around right red - it does stop it.
I'm going to bring the last one into UAS tommorow to see if they'll sell me one off some brakes they have spare, then they can order new ones to put in. I'm happy to do that if they are.
Schweeet.. Go Tim @ UAS.
I'm just hoping the wheel hub for s14 I ordered will have the correct splines to go on my cef... i'm scared.. but hopeful... but scared.. someone hold me.
Okay the final verdict is that noone will seperate them from a wreck. Noone sells them seperately and only Nissan sells a caliper "kit" that has all the little pins and metal things in it and apperantly that is $80.
Needless to say my calipers are now back on my car minus 4 little metal shims/pads.
We'll see how we go ;)
sorry dude i thought you meant inbetween the piston and pads, you mean the locators to help allign the pad. good luck id call around some reckers
I'm in build something good from it or throw it out mode at the minute. If I can find mine I'll send them to you. They have no place on my cars. And are one of the first things I pulled off...
TT
Yeah called wreckers, I might have to sit down with the phonebook the few I've called are all not seperating them or say that if the calipers aren't working they won't take those things off they just bin the lot.
Thanks Targa Tom but why do you take them off? If there's no point having them then there's no point being concerned on my part I guess... what's the go?
Those are Pad Guides. You need them...the plates/shims that everyone keeps talking about are not so important as they only help prevent squeaks. Your rear caliper should be the same as a 180sx from memory but I will find out what other car you can get the fronts from. Those pad guides are what the little feet on the sides of the pad slide into right?. Just wanna make sure we are on the same level here. Also there is a leaf type spring mechanism on top of the pads. This is semi important. Try to keep this. Look out for the next post. If all else fails, I'll track some down for you and mail the things to ya if that's what it takes for you to have safe brakes. After all, without those guides...there is a possibility under hard braking that the pad can wedge itself onto the disc and cause a massive lockup.
Well in the last two years we have done Targa Tas... There are one or two occassions when during the 500+ competitive stages we touch the brakes... No massive lock-up.
We now run two cars, one kicked off last week at Baskerville last week. He also used the brakes a few times to slow down.... no massive lock-up.
In fact I have put about six sets of front pads thru my car in two years without drama.
Could you please explain how a small anti-rattle clip is going to cause a massive lock-up.
Because I might need to put them back in?
TT
TT
Well there's no need to be a smart arse about it. Obviously you would have read the post where I said the words: POSSIBILITY and HARD BRAKING.
They are there to stop the pad from moving excessively inside the caliper. I didn't write it to scare anyone but to note the importance that these things have. Nissan don't pour millions of dollars into design and research only to have someone tell them that their money is wasted...."just throw them away". Because I'll tell you now that if he has his car insured and it happens to be in an accident, his insurance will be void because they are not there. if the pad moves around too much, he'll bend the pins, eventually they can snap or come out, then pads fly out.
I'm here to help him out and all you wanna do it hang shit.
Good one.
Good one.
"They have no place on my cars" - Please read "my"
"I'll have a look and see if I can find them" (Which I have and he can have them if he wants)" Is taht not trying to save him some readys at the wreckers?
We remove the rattle clips as a safety issue... It makes a visual check of our brakes quick and easy... and change if needed can be effected.
Now I havent been round Nissans for long... and yes know their R & D is top notch - but I have removed a lot of rattle clips. And they have never caused bent or broken pins. All the calipers we use only ever get knock off if you have a really bad tank slapper (Bikes) or hit somthing extremely hard (car)... anyhow what would I know.
"someonestolecc" if you still need them I have a set of front and rears. PM me with delivery details.
TT
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
