Japanese road laws have changed effective today (November 1st 2004)
From today, anyone seen driving while holding a cellphone can be stopped and issued with a 50,000yen fine and one demerit point.
The old laws banned ketai useage while driving . . . . . . . but the officer involved would have to show that using the ketai was impairing your driving. Hence the reeason no one was EVER pulled over for this, and everyone just ignored the law.
The same changes to the law also apply to bicycle and motorcycle riders. So be careful everyone.
IG
https://www.sau.com.au/forums/topic/54972-japanese-road-law-changes/
If you can get hold of a copy of the Japan Times from last Friday, there is a big write up of the changes in there on Pg 10.
Most of the other changes were aimed at Bosozoku. Eg
Removed or poorly fitted exhaust = 50,000 yen.
Noisy driving (such as gunning the engine) = 50,000
Refusing a breathalyzer test = 300,000
Mob riding = Instant arrest (once they catch them)
Also, all the new bank notes are being released today.
http://202.221.217.59/print/business/nb06-...b20040616a3.htm
Similar to the ones here in Aus (or Qld at least, dunno about everywhere else). The only difference is that ours is a 3 point loss and $135 fine... Y50,000 seems pretty steep!
How do you use a mobile phone on a motorbike? It's a bit hard to hear through the helmet :D
i read this earlier in the year, a few things have changed...but the most important one you should note is 60,000yen to 300,000yen fine for drink driving!
Not quite correct. That particular fine comes into play if you try and evade a breath test.
Under the old laws, it was cheaper to try and speed off, or refuse to take the test, if you saw the police breath testing on the road ahead. The new laws just correct that.
With regard to the new cellphone laws. I was slightly off.
The police can issue instant fines of 7,000 yen if they catch you talking on a ketai while driving. However, if you refuse to pay the fine, the courts can increase that to 50,000 yen.
Sorry for the misinformation. The Japan Times article wasn't particularly clear.
IG
huh...evade and when they catch you, you could be up deportation my friend...not just 300,000yen and a suspended license.
Under the old law i.e. the old smell test, they would let you go as long as they judged you still competent to drive...which was not accurate.
Furthermore under the old law they were basically not catching anyone as such!
Sure the fine for using a keitai is 7,000 yen? My wife seemed to think it was only 5,000?
Japan Today is saying that:
Small motorcycles = 5,000
Cars and Large Motorcycles = 6,000
Trucks and Busses = 7,000
http://www.japantoday.com/e/?content=news&...&cat=&id=317518
Either way, It's going to get expensive really quickly if people continue to do it.
IG
dave read this
http://mdn.mainichi.co.jp/news/20041101p2a...0dm006000c.html
funny thing is they will do this to show they are enforcing the new law but after a month or so they won't care plus 7000yen ain't that much but no doubt it will go up.
Nailed it in one Evo_Lee. Give it a month and they'll be back to normal (ie doing nothing) and people will just start using their ketai in their cars again.
Pathetic isn't it.
IG
well, I have to admit the new fines don't really bother me...I'm a good boy me :innocent:
I never talk on the phone while driving. :(
Certainly don't drink and drive. :alcoholic
And my cars are 100% legal...and when I want to have some "fun" I pick the time and the place with care :angel:
:(:D :D
Drive smart people and pay less tax :D
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
