track/drift day saturday January 15th $150bux
  • Replies 372
jas the 5th in the latest but if there are still spots for the day after that we will abviously take them as well
passenger are welcome on the day to sign up
100kg of balastlol
yea that will be great eaven out my 135kgs on the drivers side
I did one of pete's days and took a 90kg bloke out in my n/a 4 door. the thing wasn';t drifting so i blamed it on that.
then the other week pete drove my 4 door at wakefield. with our combined 240kg he managed to have the car sideways around the entire track and destroy the rears twice in the space of 5 mins.
team fatboy dfrift can eb done. it's a goer!
i may have to join in on the team fatboy drift.
just need a tyre donator. only thing is that i dont have enough rims to take with me.
i.e only have 6 rims. = only 2 spares to drive home on.
i do have some 17" wheels but the rubber is shot.
For drifting....a tyre is only stuffed when either:
1. IT goes bang
2, The steel belts are hitting the guards
All other rubber should be donated to the smoke gods
Go team fatboy !!!
well ill be doing my burnout in my 4 door. mark h you keen to take my 2 door out for burnout?
with shitty squat seems hard to keep in 2nd gear on the brakes. so ive just been using 1st for my burnouts. sucks but hey. maybe it's my lack of talent.
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
