track/drift day saturday January 15th $150bux
1. arkhaeon luke waldon payed (10/12)
2. de pau neil payed (10/12)
3. Daniel burton payed (10/12
4. Adam more payed (17/12)
5. Unknown deposit(cash) payed
6. GBS payed (29/12)
7. jarich Daniel payed (29/12)
8. “”jarichs mate payed ””””””
9. j buckton payed (30/12)
10. “””””””” payed ”””””
11. cheque(unknown) payed (30/12)
12. 4door aml payed”””””
13. drift day (unknown) payed (31/12)
14. Ashley bogdana payed “””””
15. steve Simmonds payed “”””””
16. Christopher john payed “””””
17. mana pholsena payed “”””
18. Anthony buckton payed (4/1)
19. grant marshel payed “””
20. “””””””” payed “””
21. wayne/barry walker payed “””
22. “””””””’””””””” payed”””
23. Andrew Vitu payed”””
24. Jason au payed””(pulled out)
25. willie wong payed”””
26. craig payed (5/1)
27. “”””” payed 1”””
28. vecchinos payed “”””
29. linda mccar payed (6/1)
30. garry john blogg payed”””
31. “”””””””””” payed””””
32. “”””””””””” payed”””
33. fernado (tyre machine payed (7/1)
34. Richard hong payed (15/1)
35. Adela Rourke payed (10/1)
  • Replies 372
Pete,
Will there definatly be a tyre machine there on the day ?
I was also thinking of bringing my trailer with compressor, rattle gun and spare tyres.
Is this needed (compressor) ?
I CAN't WAIT for Saturday:wassup:
I think it is the best idea as I hate changing wheels, so having the right tools will make it easier.
Pete, Will the pit garages be open for us to use ?
If so I put my dibbs on one.:headspin:
Mal, bring it all mate... was going to pring my compressor, but if you have yours all packed then saves me digging mine out! (Still at the back of the garage behind all the still unpacked boxes from our move!)
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
