wrxhoon,
I am interested I will PM you, I have lost your number. Thanks.
Busted Zed,
Come on pretty boy, the number of times your nissan has been immobile and you want to mouth up about me being soft because of bald tyres. I will keep the lipstick comment, and ensure I dish it back to you the first time you soft up on me. I checked out the forecast and it said rain, but I still intend on turning up. John do you want to do a wet weather challenge. I will give you .5 sec start.
  • Replies 97
Hey Doughboy we do heaps of track days and drift and now drags and the zed is strong and we push it hard it is not a dyno queen.
Paul yes if wet not on so you can keep your 4wd which would flog me for sure. I wonder how much you would beat me by with 4wd in the wet and then disconnect your front drive shaft and we race rear wheel only in dry. Zed says CYA.
By the way just got home from late night tune after some more tinkering we have been doing last week. Just hit 401rwkw with no more boost and no loss down low with more mid range and top end. Makes 200rwkw at 3400rpm. 10s here we come. Hope weather is good. If rainy or looking like rain then it will be off. If a dog looks like pissing in the marshalling area it is called off.
John, a local workshop by the name of RUF Performance has offered to do the dyno run and boost tune for the same price you offered me, so I'll go with them (much closer), hopefully I'll see you tomorrow night!
I'm still so excited and at the same time very nervous
10s here we come.
You've said this before, John. To be fair though mate, your car could of done it the other day with the right tyres instead of those horrible P-Zero shit-bombs.
You bought Pirelli Slicks for the track cos they're what you're supposed to use - do the same with drags and you'll run the easy tens you never knew you always wanted :D
Adrian
Well I went out and bought some new tyres last night so Im am all clear if it does not rain tonight.
How do we know if they have called it off, I have an optional meeting from 5-6pm today so I would like to go if the Drags are off.
John, assuming its clear, what time are you heading down?
I am keen and will be there around 4pm I guess. Sunny now this morning but forcast rain so? Does anyone know of a website or do we do the old fashion thing and call WSID to see if on?
Yep 2rismo got the drag wheels and tyres now, line locker and more, just to slam dunk it.
Dezerteagle no probs we are flat out anyway and hope to see you out there. There will be plenty of zed bait for you as a few coming.
Hey B man such confidence now. By the way you coming with the beast?
Paul if your engine falls out then I might listen otherwise get there, and put your lipstick back in your purse.  Or was some wimp from work posting for you?
Look out boys, the boat owner is getting mighty c0cky.
Guest two.06l
I thought you were sick, I have spoken to your mum and she told me if you didnt work you cannot play. :jk:
Can't believe it's going to rain, I got 70kw out of the car for tonight, this morning.
John, I think you should read this thread too, 70kw for $70
http://www.skylinesaustralia.com/forums/sh...ead.php?t=55542
The mechanic said the timing was set all the way back.. he advanced it abit and says its ok since there is no pinging and it's still running very rich.
Have you practiced with the line lock yet John? Simple on paper, harder in reality...
Can't wait for tonite providing it's on. Just wish the Hawks weren't playing as well. I'm so torn... AAHHHH!!!!!
Even have some fuel lined up to keep the timing into it :P
Someone out Penrith way get these clouds to ***rightoffplease!
Adrian
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
