Why is it Nissan have used 2 fuel pressure regulators on the R32 GTS-T (I'm unsure if they also did it on the R33)
One fuel pressure reg. is at the back of the fuel rail near the firewall. This one receives the fuel and passes it on to the injector rail.
The other is at the front of the fuel rail towards the front of the car that feeds the fuel to the return to tank fuel line.
Is there any reason or benefit from this setup or does it simple help hold fuel pressure in the rail and prevent the fuel pump from working as hard as often??
That's the first time I've ever heard or there being two. I'm not sure where you saw that but I have never seen it. I know that when you add and aftermarket one, you leave that standard one on as a backup device to prevent total loss in case of new reg failure.
I also noticed this when I put my new injectors in.
My back one wasn't even connected, the hose going to it was all split and stuffed, so I replaced it when I put the new injectors in
I wonder if thats why my car an so lean..........................
You'd think a decent mechanic would pic something like that up hey.
When I swapped the injectors, I found 4 vacuum hoses with leaks in them/or not connected
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
