  • Replies 52
The RTA says 15mm change is ok in the overall tyre and rim combo, BUT every dumb ass coppa i've been defected by says, "1inch higher, 1inch wider ONLY"
I think he was talking about his man hood. Go stick a 350z tyre placard on the car, problem solved as these only say Nissan on them.
Read the document in your first post. These are the ones that apply to you:
An important requirement for all replacement wheels is that the wheel track must not be increased by more than 25mm beyond the maximum specified by the vehicle manufacturer for that vehicle.
Wheels up to 26mm wider than the largest optional wheel recommended by the vehicle manufacturer for the vehicle can be fitted without the need to notify the RTA.
The outside diameter of the wheel and tyre combination must be no more than 15mm over the largest diameter wheel and tyre combination specified for the vehicle and not more than 15mm below the smallest diameter wheel and tyre combination specified for the vehicle.
and
• The wheel and tyre must be contained within the body work or mudguards (including any flares) when the wheels are in the straight ahead position.
• The wheel and tyre must not foul any part of the body or suspension under all operating conditions.
• Speedometer accuracy must be maintained for the selected tyre and rim combination.
• The fitment of wheel spacers (or adaptors for dual wheel conversions) between the wheel mounting face and the road wheel is not permitted unless fitted as original equipment by the vehicle manufacturer.
So... as has been mentioned previously, as long as the overall rolling diameter of the wheel/tyre combo remains within 15mm of stock (by putting lower-profile tyres on bigger rims, which you'd do anyway), you don't go more than an inch wider in the rim (any sized tyre is fine, as long as it fits on the rim safely), and you don't make the track more than 26mm wider than stock, you're fine.
Why the confusion? You put a link to all the answers in your first post!
All of the answers are there in black and white, people's life stories have nothing to do with your not reading the document properly.
If you're still worried, get the sizes of the wheel/tyre setup you want, and contact an engineer (or "signatory" as the RTA document refers to them). They'll tell you for sure if the wheels and tyres adhere to the rules in the document, and if they don't, but they deem them to be safe, they can issue you with an engineer's certificate, which makes them legal anyway.
lol mate im not the immature one thats getting cut over a forum
mature is not about being rude
maybe i missed a few things, maybe i like to speak to my mates on a forum
i didnt ask 4 your negative input.
heres a "mature" quote for you buddy
"better to remain silent and be thought a fool than to speak out and remove all doubt"
Point to the bit where I was rude. All I did was offer advice and say:
In other words, re-read the document and you'll have your answers.
I fail to see how interpreting the document you were too lazy to properly read (and providing you with an answer to the question you asked) is negative input. I have not picked on you for talking to your mates on a forum.
Maturity is a lot more than cutting and pasting quotes... and perhaps you should take your own advice.
Finally, here's a pic of the tyre placard.
As you can see, it's clearly labelled Nissan Skyline, it is also very thick, and shimery. To me it looks and feels real. So to Police I'm sure it would look and feel real to them too. Besides, I don't see why it would be a fake.
One thing though... I have 235/40r18 on 18x9's... The placcard suggests I should have bigger tyres?? If I did they would scrub... meh. All good.
wil..
What was the "largest optional wheel" recommended by Nissan for the R32 GT-R? Obviously it came with 16x8s, but the wording seems rather dubious to me as it suggests it is based on what Nissan recommended as the largest size (ie. on the tyre placard)?
Lucien.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
