  • Replies 52
The RTA says 15mm change is ok in the overall tyre and rim combo, BUT every dumb ass coppa i've been defected by says, "1inch higher, 1inch wider ONLY"
I think he was talking about his man hood. Go stick a 350z tyre placard on the car, problem solved as these only say Nissan on them.
Read the document in your first post. These are the ones that apply to you:
An important requirement for all replacement wheels is that the wheel track must not be increased by more than 25mm beyond the maximum specified by the vehicle manufacturer for that vehicle.
Wheels up to 26mm wider than the largest optional wheel recommended by the vehicle manufacturer for the vehicle can be fitted without the need to notify the RTA.
The outside diameter of the wheel and tyre combination must be no more than 15mm over the largest diameter wheel and tyre combination specified for the vehicle and not more than 15mm below the smallest diameter wheel and tyre combination specified for the vehicle.
and
• The wheel and tyre must be contained within the body work or mudguards (including any flares) when the wheels are in the straight ahead position.
• The wheel and tyre must not foul any part of the body or suspension under all operating conditions.
• Speedometer accuracy must be maintained for the selected tyre and rim combination.
• The fitment of wheel spacers (or adaptors for dual wheel conversions) between the wheel mounting face and the road wheel is not permitted unless fitted as original equipment by the vehicle manufacturer.
So... as has been mentioned previously, as long as the overall rolling diameter of the wheel/tyre combo remains within 15mm of stock (by putting lower-profile tyres on bigger rims, which you'd do anyway), you don't go more than an inch wider in the rim (any sized tyre is fine, as long as it fits on the rim safely), and you don't make the track more than 26mm wider than stock, you're fine.
Why the confusion? You put a link to all the answers in your first post!
All of the answers are there in black and white, people's life stories have nothing to do with your not reading the document properly.
If you're still worried, get the sizes of the wheel/tyre setup you want, and contact an engineer (or "signatory" as the RTA document refers to them). They'll tell you for sure if the wheels and tyres adhere to the rules in the document, and if they don't, but they deem them to be safe, they can issue you with an engineer's certificate, which makes them legal anyway.
lol mate im not the immature one thats getting cut over a forum
mature is not about being rude
maybe i missed a few things, maybe i like to speak to my mates on a forum
i didnt ask 4 your negative input.
heres a "mature" quote for you buddy
"better to remain silent and be thought a fool than to speak out and remove all doubt"
Point to the bit where I was rude. All I did was offer advice and say:
In other words, re-read the document and you'll have your answers.
I fail to see how interpreting the document you were too lazy to properly read (and providing you with an answer to the question you asked) is negative input. I have not picked on you for talking to your mates on a forum.
Maturity is a lot more than cutting and pasting quotes... and perhaps you should take your own advice.
Finally, here's a pic of the tyre placard.
As you can see, it's clearly labelled Nissan Skyline, it is also very thick, and shimery. To me it looks and feels real. So to Police I'm sure it would look and feel real to them too. Besides, I don't see why it would be a fake.
One thing though... I have 235/40r18 on 18x9's... The placcard suggests I should have bigger tyres?? If I did they would scrub... meh. All good.
wil..
What was the "largest optional wheel" recommended by Nissan for the R32 GT-R? Obviously it came with 16x8s, but the wording seems rather dubious to me as it suggests it is based on what Nissan recommended as the largest size (ie. on the tyre placard)?
Lucien.
    • Ok, so first round of maintenance done. I didn't get much history with the car but I know it was well looked after. That isn't enough for me though, so ...  I had to do the oil filter housing gasket. It was leaking a lot, and also as part of that I did the anti-return valve and the VANOS oil line (from HEL).  But, then I got hit with the while-ya-in-there's. Did both accessory and A/C belts, tensioners and pulley. The accessory belt that came off had a huge hole in it, like somebody hung it up with a nail. The pulley and tensioners seem ok, so I'll keep those just in case. I did water pump and pump pulley. The water pump had a small bit of play so timing was good.  I also did fan clutch. I don't know how to test the old one but between the water pump and the fan clutch the car is running a little bit cooler (not much ~2 - 3 degrees maybe) so good result. Unfortunately the thermostat and housing didn't turn up in time so I'll shelve those. I have no concerns at all on the current ones.  Then I spent what seemed like 40 days and 40 nights bleeding the air from the cooling system. She also got new air filter, fuel filter and did a Mobil 1 change with oil filter. Hilariously, not an hour after telling my wife how proud I was of myself to be going slowly and meticulously and making sure everything was torqued and nothing missing I went and started it without the oil filter in. The car complained immediately of no pressure and after only a few seconds I turned it off and discovered a shit tonne of oil on the driveway. Sigh. I've driven it since and thankfully doesn't seem to be any problems. AND THEN during the test drive a ratchet extension fell into the battery area in the boot and JAMMED right next to the positive terminal and the car body. Like, just touching it made sparks and it was jammed in there. So, almost killed the engine and then almost burned the car to a crisp. Good start. This was the rails under the splash guards. So stoked, she's straight as and super clean. No rust anywhere. There was a heap of caked dirt that I removed but otherwise looked great. All 4 jacking points are perfect.   Next I want to service the gearbox. Sometimes it's a little reluctant to shift up and I'm hoping a fluid change will sort it. I also have 4 new rear subframe bushes. They're as big as a toddler. I'm renting a tool to help put them in. I can't wait for this because its a bit crashy back there at the moment.
    • Remember when those donkeys kept using freedom units and smashed that satellite to bits on the moon? NASA has their brain switched on and uses the metric system.
    • Don't use "gasless MIG" (FCAW) you want to use proper MIG. FCAW burns a few hundred degrees hotter than MIG will for mild steel. It is a true ball ache for sheet metal. New MIG / TIG machines even have features like "Spot Weld" as well as "Automatic" settings. Plenty of people say for DIY home hobby, the auto machines are pretty good for 95% of welding. I personally, I'm a sucker for punishment and wanting to dial it in, and be able to adjust the machine. Mainly because I used to MIG weld for a living, and being able to tweak and tune things ever so slightly was my preference. Hence when I bought my ACDC TIG, it has all the adjustments for everything and no "easy" mode. Ha ha I have stick, MIG, "gaslessMIG" and ACDC TIG at home. Out of them, if you're doing mild steel sheet metal repair, and want to do mild steel exhausts, go MIG. If you're thinking you'll want to get into doing some aluminium stuff, or stainless steel, get an ACDC TIG with HF start. If you can, get one with a foot pedal too. My MIG machine is a UniMIG, and my Stick/TIG is CigWeld. If I were buying another machine, I'd buy another CIGWeld. Lots of people having issues with UniMIG, and them not wanting to cover warranty. Everything has to go back to UNIMig themselves. CIGWeld, I've had to use their warranty on my machine for a gas leak, they have repair centres everywhere, (contracted authorised repair centres). First repair place I used were hopeless, but the second place were amazing. Warranty process itself super easy, and second repair place was telling me CigWeld actually cover in their warranty, upto an hour of techs time to help you with your machine, and going through the settings and helping teach you the machine. UniMIG keep trying to get out of replacing motherboards on 12 month old machines.   TLDR, mild steel sheet welding, buy a MIG. my vote is CigWeld for brand.
    • I guess that's what happens when someone can't convert metric to freedom units to machine something. 😛
    • I've watched some vids and the technique seems to be to butt the sheets up to one another and use MIG to spot weld and slowly fill in the spots until its eventually all sealed. No runs as you would normally do, as there's too much heat generated that way. Yeah my stick welds are terrible these days because its been so long since i've done any of it. I expect to be spending many hours practicing
