i was out in woden about an hour or so ago when the storm had just started, what a bastard. hail everywhere, there wasn't any place with cover i could pull in to, cos it was hailing. visiblity was 0. and to top it, some idiot in a old school torana or something broke down in the middle lane of that intersection going past hindmarsh towards fyshwick, he had no hazard lights, almost caused a few crashes.
sigh
I can tell you about west westside, huge storms rolling through, hail, wind, lightning etc etc really big in Gundagai/Tarcutta area at 1400hrs. ETA Canberra 1600hrs estimated [by me], its heading your way.
i feel your pain... i had to close the garage while it was shitting ice yesterday.
On a lighter note. My nieghbors Soarer got pummeled as it was parked on the nautre strip during the storm. Nothing serious but if you look closely you can see slight indentations on the roof
bloody ANU got hit with a shitload, you could barely see. i was safely in the library studying however.
Sullies creek is overflowing now, not a pretty sight what with all the dead animals and trollies in there
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
