Hi everyone,
Been a while since I have been on the forums,
But unfortunately today I was stickered for my headunit. Yes, believe it or not but this is true.
I don't really want to go into the details but they overlooked some little things such as the cam gear cover on the front of the motor which has been removed (they didn't say anything about it). However, as I need to go over the pits, I am just trying to source a cam gear cover for an RB26, just in case it is required in order to pass.
Does anyone have one of these?
Any help is greatly appreciated.
Thanks
Dan
https://www.sau.com.au/forums/topic/55085-copped-a-nice-yellow-sticker-today/
i got yellowed also
need a 3 inch cat dudes to borrow , same deal , lemme know if you got one :D
Are you running standard brakes? if so would that pass?
Did anyone get done on Wanneroo road when there was that 'blitz' with all cars regos checked etc, apparantly about 120 (might have been 170) yellow stickers given out over 4 hours. I probably would have got one if I as going that way (was going in the opposite direction) as my exhaust is being held on by coathangers at the moment... (all getting fixed tomorrow)
What I heard today with yellow stickers (dont know if its true or not) but depending on the angle of the sticker depends on the severity of how badly the pit inspectors will rape you. For instance, a straight sticker says "This guy is alright, dont give him a hard time", a wonly angle is "Find as many faults on this wanker as possible" and upside down is a "Do not pass whatsoever."
I wonder how true this is, cos I've never heard of a cop putting a sticker on upside down.
its all true the further the sticker is from straight the worse the cop thought of you but the pit boys dont always go for it my mate got 3 stickers in 1 month all on nasty angles by the 3rd the pit boys sed tell the cop to go jump this car is perfect and didn even check it
it is true folks about the angle of the yellow sticker. If you cop one get your car home ASAP wet the sticker and make it straight.. Believe me it works
It used to be that if you gave the cop a bit of shit for giving you a sticker, they would put it horizontally on the windshield, which told the inspector at the pits to go right thru' your car and find everything possible for you to get fixed. Basically to give you a hard time.
Yeah, it was common to steam the sticker and set it vertically, that way the inspector was oblivious to the goings on at the time the sticker was issued.
Occasionally, we took a gamble and removed the sticker and hoped like hell that the cop didn't follow it up. You could be garanteed that the cop would follow it up if you had given him a hard time. These days, I'd say that everything is entered into the computers, so licensing will always know that yellows have been issued.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
