discopotato03 Posted November 4, 2004 Share Posted November 4, 2004 Guys the 2530 is a tarted up Garrett GT28RS and the GTRS is a tarted up Garrett GT2871R . Search ATP Turbo.com for details , Brett at GCG should be able to import and emulate the things for nothing like $4000 . ATP will also sell either cartrige seperatly for under $1000 US . For the record the GT28RS comes with a .86 AR turbine housing which is essential for 2 liters and up . The only problem is I'm not sure if Garrett or HKS make a T3 flanged .86 housing . Brett is having adapters made up and the combination will work heaps better than the .64AR . Std dump wont fit though SR20DET ones will . Cheers A . Link to comment https://www.sau.com.au/forums/topic/55091-hks-gt2530/page/2/#findComment-1076688 Share on other sites More sharing options...
SeriesIIGTST Posted November 4, 2004 Share Posted November 4, 2004 After reading lots and speaking with people, I decided on one step up from the 2530 being the 2535 on my RB25. It certainly doesn't make 511rwps or even 438rwhp for that matter but the best i've seen out of it is 339rwhp @ 16psi and more recently, i've had it "street" tuned at only 12psi for 300 rwhp. Now I can tell you 220rwkw in any gear is a lot of fun. I've not run the track yet but I'd hope for low 13/high 12 and if Sly33's results are anything to go by, it should do it. Given that 12psi is hardly in the HKS 2535's efficiency range, it's safe to say that if I were to wind the boost up and get it retuned, everyday 250rwkw would be easy. Unfortunately for me, the fuel pump and my injectors don't keep up with that power for the moment so I've left it at 12psi. The 2530, 2535 and even the 2540 are not big turbos. If you're chasing the big numbers, don't get one. If you're after quick response, good street power and about 250rwkw, buy one and be happy Link to comment https://www.sau.com.au/forums/topic/55091-hks-gt2530/page/2/#findComment-1076699 Share on other sites More sharing options...
lukits01 Posted November 4, 2004 Share Posted November 4, 2004 339rwhp@16psi Would it be necessary to lower compression at that ammount of boost? or can the RB25 handle a bit more? I know it depends on the tuning, but just wondering what kind of boost people with GT2530/35/40 are running to make max power with standard compression Link to comment https://www.sau.com.au/forums/topic/55091-hks-gt2530/page/2/#findComment-1076790 Share on other sites More sharing options...
croat Posted November 4, 2004 Share Posted November 4, 2004 If anyone is after a HKS turbo upgrade get the GT-RS! my mate has this installed (at BD4's) and its nuts! I will have mine on in a weeks time just labour at the moment. The gt-rs is honestly nothing short of nutz! 1st to 4th gear is just wheelspin without dumping clutch, no lag, consistent power curve. The car really get's up and goes. I will make a thread on this in the coming week and show all the results. So far i highly reccomend it! Link to comment https://www.sau.com.au/forums/topic/55091-hks-gt2530/page/2/#findComment-1076804 Share on other sites More sharing options...
SeriesIIGTST Posted November 4, 2004 Share Posted November 4, 2004 339rwhp@16psiWould it be necessary to lower compression at that ammount of boost? or can the RB25 handle a bit more? I know it depends on the tuning, but just wondering what kind of boost people with GT2530/35/40 are running to make max power with standard compression To be quite honest, I wouldn't know. I've got a fully rebuilt RB25 with forged pistons so I don't have to worry quite as much. Mine happily boosted away on 16psi but my PFC flashes up 100% duty cycle on my injectors which is why my street tune is back to 12psi. Once the injectors get upgraded and the fuel pump upgraded, i'll probably screw 18psi into it as that's where these turbo's like to operate (approx 1.2bar) Link to comment https://www.sau.com.au/forums/topic/55091-hks-gt2530/page/2/#findComment-1076889 Share on other sites More sharing options...
SeriesIIGTST Posted November 4, 2004 Share Posted November 4, 2004 If anyone is after a HKS turbo upgrade get the GT-RS! Do these come in T3 flange? I thought they were only GT25? GT-RS has same compressor housing and turbine wheel as GT2535 and GT2540 but a bit larger trim if i'm not mistaken. Although output on GTRS is 400 vs 340 and 350 on the 2535 and 2540 respectively. All are slightly larger than 2530 which is what this thread was about in the first place. Link to comment https://www.sau.com.au/forums/topic/55091-hks-gt2530/page/2/#findComment-1076894 Share on other sites More sharing options...
Lithium Posted November 4, 2004 Share Posted November 4, 2004 I am pretty much in the same boat at the moment, and am not too sure that I can afford a reasonably larger than stock turbo - let alone the supporting mods right now. I have been doing some research, and it LOOKS to me based on the comments throughout here on GT2530s etc that a TD05-big 16G from a Mitsubishi EVO3 (and some others) would do a similar job. They seem to be good for the 340-380hp range, depending on where you look and how you set it up. I've actually not found any solid evidence of anyone running one on an RB motor, especially RB25DET. Does anyone have any thoughts on this? I realise I'd need to do some mods to use it - but considering I can get one for $500-600 its not too bad Mitsi turbos Link to comment https://www.sau.com.au/forums/topic/55091-hks-gt2530/page/2/#findComment-1076942 Share on other sites More sharing options...
SLY33 Posted November 4, 2004 Share Posted November 4, 2004 339rwhp@16psiWould it be necessary to lower compression at that ammount of boost? or can the RB25 handle a bit more? I know it depends on the tuning, but just wondering what kind of boost people with GT2530/35/40 are running to make max power with standard compression Well when i first got my car back, it had been tuned to be safe at 1.39bar! Straight away i voiced my concern to my tuner but he assured me its safe. On cold nights i regularly see 1.39bar. I have a completely unopened motor with the stock 9:1 compression. I do get the occasional knock if the fuel is bad. Many would say thats excessive, and id even agree with them! But so far its been fine, and as i plan to rebuild the motor soon anyway it doesnt bother me. So going on how my motor handles it, id be saying 1.2bar with good tuning should be fine on a "healthy" motor, although for peace of mind go the head gasket and 8.5:1 comp. as for the GT-RS, its a newer turbo rated higher than the 2530/35/40 and designed to fill the power/response gap in the old GT series, so i dont doubt it'd be the pick of the bunch, but as with every other mod, it depends on how much you want to pay, as the old GT25 series can be had fairly cheap even brand new. Link to comment https://www.sau.com.au/forums/topic/55091-hks-gt2530/page/2/#findComment-1076966 Share on other sites More sharing options...
croat Posted November 4, 2004 Share Posted November 4, 2004 Do these come in T3 flange? I thought they were only GT25?QUOTE] series2gtst yeah they just released them in a T3 flange type for gtst's. They really work a treat! Link to comment https://www.sau.com.au/forums/topic/55091-hks-gt2530/page/2/#findComment-1077077 Share on other sites More sharing options...
Trust33 Posted November 4, 2004 Share Posted November 4, 2004 What are they croat.The 400ps rated gtrs with t3 flange and all acessories For the gts-t $2564.55 from nengun. If i were to run a gtrs turbo and wanted 230 rwkw,for now untill i had enuff money for a rebuild on the engine,what psi would it be running at.Knowing that i have all the supporting hardware bar turbo and forged bottom end. I think these turbos run up to 300rwkw.If i am correct about what a ps rating is. Can someone explain to me what a ps rating is. Link to comment https://www.sau.com.au/forums/topic/55091-hks-gt2530/page/2/#findComment-1077178 Share on other sites More sharing options...
croat Posted November 4, 2004 Share Posted November 4, 2004 Trust33 ps means "power stroke" its approximately 400hp rated (thats what i have been told). The turbo come with all accessories you need to fit it to your gtst, gaskets, lines, elbow etc... I have the turbo and have standard bottom end, and so does my mate. He runs 1.3 bar all day every day, i will run around 1 bar (just to keep things safe). At 1 bar i am expecing around 240 rwkw. I think this turbo can run up to 300rwkw but u will need forged internals and a lot of boost, cams etc... Trust33 why rebuild the engine if you dont need to, just wait till it dies. Link to comment https://www.sau.com.au/forums/topic/55091-hks-gt2530/page/2/#findComment-1077203 Share on other sites More sharing options...
Trust33 Posted November 4, 2004 Share Posted November 4, 2004 Thats what i will be waiting for.How did it bolt up to the stock manifold+dump.And did you need a custom intake pipe? Like u say great turbocharger and it is internally gated. Link to comment https://www.sau.com.au/forums/topic/55091-hks-gt2530/page/2/#findComment-1077267 Share on other sites More sharing options...
gtst25 Posted November 4, 2004 Share Posted November 4, 2004 If you're going to rebuild it'd be interesting to see how a gtrs goes with rb30 bottom end/bigger cams! Link to comment https://www.sau.com.au/forums/topic/55091-hks-gt2530/page/2/#findComment-1077553 Share on other sites More sharing options...
SLY33 Posted November 4, 2004 Share Posted November 4, 2004 damn that gtrs kit is an absolute steal! if only i didnt have the 2835 on order! Link to comment https://www.sau.com.au/forums/topic/55091-hks-gt2530/page/2/#findComment-1077623 Share on other sites More sharing options...
croat Posted November 4, 2004 Share Posted November 4, 2004 Bolts up easy to stock manifold and dump (i will find out for myself next few days). I think the gt-rs will be too small a turbo for an rb30, better off going a 2835. My oppinion... Link to comment https://www.sau.com.au/forums/topic/55091-hks-gt2530/page/2/#findComment-1077814 Share on other sites More sharing options...
gtst25 Posted November 4, 2004 Share Posted November 4, 2004 Bolts up easy to stock manifold and dump (i will find out for myself next few days). I think the gt-rs will be too small a turbo for an rb30, better off going a 2835. My oppinion... Thought the gtrs was a bigger turbo - people seem to be getting more power from these than 2835??!! Link to comment https://www.sau.com.au/forums/topic/55091-hks-gt2530/page/2/#findComment-1077935 Share on other sites More sharing options...
croat Posted November 5, 2004 Share Posted November 5, 2004 Nah 2835 is more top end power, and GTRS is more responsive. Link to comment https://www.sau.com.au/forums/topic/55091-hks-gt2530/page/2/#findComment-1078230 Share on other sites More sharing options...
Drivebai Posted November 5, 2004 Share Posted November 5, 2004 hey Croat can i ask how much you are paying for the GT-RS kit? was thinking about getting the 2530 but now that you mentioned this one.. hmmm Link to comment https://www.sau.com.au/forums/topic/55091-hks-gt2530/page/2/#findComment-1078417 Share on other sites More sharing options...
Trust33 Posted November 5, 2004 Share Posted November 5, 2004 Craot when u put the hks on you will have to tell all.and post up a dyno sheet. Link to comment https://www.sau.com.au/forums/topic/55091-hks-gt2530/page/2/#findComment-1078499 Share on other sites More sharing options...
adznight Posted November 5, 2004 Share Posted November 5, 2004 Yup! Make sure you get a dyno run before and after for us Link to comment https://www.sau.com.au/forums/topic/55091-hks-gt2530/page/2/#findComment-1078513 Share on other sites More sharing options...
