Some times I take off in second as I find it quicker to get out in front of traffic. :D
Have a read of the thread in Forced Induction.
http://www.skylinesaustralia.com/forums/sh...ead.php?t=55503
I've been muttering to myself a little but I've came to understand the issue I've had on the stock ecu.
Exhaust Reversion.. :)
I'm running N/A cams and a stock turbo (rb20t). The N/A cams have a decent overlap that with the high manifold back pressure causes exhaust reversion when coming on to boost (where exhaust reversion is noticed the most).
Only way out is a set of adj. cam gears, different cam and or a larger turbo.
The 3ltr is the way to go though. Make sure you select the right pistons to keep that factory .045-.050" squish otherwise you will drop in economy instead of picking some up. The rod angle of the 3ltr with the right squish "should" provide a more efficient engine.
  • Replies 49
I used a ryco when cycling my oil.. Hopefully it stopped all the stuff.
I was at UAS the other day so I picked up a JIC oil filter (j-brand) so we'll see how that goes - good idea about cutting it open I never thought of that (duhh).
Will let ya guys know what it looks like (although I must admit my oil is a better colour than when the ryco was on it).
For those who are interested in buying Amsoil oil filters, I spoke with Bruce and for Melbourne area people you can go to;
Lubrication Management Systems
127B Lonsdale St
Dandenong
(ask for Bill Reid, top bloke)
Now, as for me, Geelong has an Amsoil distributor;
Zoom Master
31 Barwon Tce
Geelong
(ask for Kevin)
There are 2 main oil filters for the RB25DET, SDF15 & SDF34. The SDF34 is the recommended one, but the SDF15 will fit and is almost an inch larger, has the exact same filtration properties (10-15 microns), 7-9psi pressure dif valve, retention valve, etc.
I'm going to head down next week to Zoom Master and just make sure the SDF15 fits.
PS. For those maybe wanting to do a group buy, Bill said he'd do a good price, I just can't be farked!
:P ... Kyran
  • 1 month later...
I just pulled apart a cooper. I went to autobarn to get some of the $3 specials a while ago and the guy said be very careful with them as a friend stuffed his motor when some paper came loose. I have used them in the family cars for the past 3-5 years no worries. He reckoned change them every 5k saying the rycos are better.
I read an article on the net praising the coopers but wanted to see for myself.
This one here has been in the gfs 91 model corolla for 10,000kms with oil change at 5,000 kms. (Engine has 220k kms on it). Oil filter shown is Z386 - for skyline it is Z145a, but I assume all coopers are of a similar standard.
Things to note. There was plenty of oil still in the filter which means the anti drain back valve was still working fine. You can usually tell this by the weight (comparing to new filter)
The can and spring (spring is to keep pressure on the Anti drain back valve
The parts - from left, paper filter, case, spring, Anti drain back valve
By pass valve at bottom, cannot see too well. You can se the little holes to allow filtered oil to flow through to the centre section.
Paper filter
I have new Nissan and cooper oil filters at home. On visual inspection the holes shown in the 3rd pic are larger on the coopers than the nissans, probably not a great thing as if the paper did give way then more chance of a larger piece making its way into engine. I have 2 coopers for a corolla at home and it seems the newer coopers have larger holes whereas older ones had more smaller holes. Don't know why they changed, probably not a big deal at all. After 10000kms the paper was still pretty firm and didn't appear as if it would give way. It didn't tear really easily.
I'm going to stick with the coopers. Never had a dodgy seal either whereas I've heard people with Rycos having probs.
  • 4 weeks later...
Now that I'm due for another change of oil filter (oil leaked out + new sump + new oil) other than having to trek to UAS for a JIC filter (which seemed to keep my oil a nice consistency/colour) are there any other brands to try?
Ryco I'm not impressed with (have heard too many bad things). Paper filters I'd rather shy away from if possible.
Does anyone else know of any good brands or recommend anything? What do all the track hounds use?
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
