Cops know - everyone is innocent :(
But yes. It would be interesting Reidles - especially if you have insight into the HWP operations. As I understand it (and as most laws) there's the law of the police and law of the lawyer. So sometimes what goes down on the street isn't always right and if you have the money can be thrown out at court.
On the other hand I'm sure alot goes down in court that wouldn't be brought up on the street either.
https://www.sau.com.au/forums/topic/55112-cops/page/3/#findComment-1131790
  • Replies 56
I got pulled over by a speed camera operator before...and lectured about my speed, but he said he couldn't prove anything cause he was on his own? Good admission!
But I did point out the fact; the reason I overtook him, at what appeared to be a great speed, was because he swung out of a side street and cut me off on the main road and I didn't feel like plowing into him.
https://www.sau.com.au/forums/topic/55112-cops/page/3/#findComment-1131824
I only have insight for some operations and rbt locations for my area only. But wouldn't be in my best interests to tell everybody because that would defeat the purpose. Of course if i come across or hear of a major defect operation for example i will post a message to warn everybody, even though i am immune to it, because i know how annoying a defect can be.
For all your info i can possibly assist with things in the Hurstville, Blakehurst, Beverly Hills, Kingsgrove, M5 East from Beverly Hills towards city, Princes Hwy towards cronnulla from Kogarah and the general southern regions.
Cheers
https://www.sau.com.au/forums/topic/55112-cops/page/3/#findComment-1133215
gR33ddy as far as what you can and cant have, its completely up to you. Technically anything different from the stock specifications is classed as a defect. All mods should be ideally engineered to pass road regulations (But u wouldn't waste your time). Most police will look for the most obvious defectable parts on the engine ie. large turbo, fmic, chrome piping and BOV's. If you modify a vehicle try and do it with boltons that dont stick out and u will probably get away with it. Then again if you are really concerned about it, spend a fortune and get mods engineered and keep papers in the glovebox. This way you dont have a problem.
I have many obvious engine and vehicle modifications on my vehicle but unlike the rest of you, i dont get the pleasure of being hassled.
https://www.sau.com.au/forums/topic/55112-cops/page/3/#findComment-1145624
I believe a cop must follow you for 'x' km's before they can guesstimate you as speeding (I think X is about 100m, i'll ask mum this wkend when she comes home).
Ive heard something along the same lines. Is your mum a cop??
https://www.sau.com.au/forums/topic/55112-cops/page/3/#findComment-1146850
I was going down to the south coast for a holiday on monday and unfortunatly, this means going through liverpool which is a cop defect magnet.
Never had a cop ask about my car before, but as luck would have it, i got pulled over for rbt and then the cop told me to pull over because he was going to defect my exhaust. I was with another car load of people in a corolla and my car was full of bags and fishing reels etc. In the end, I think he realised that he wouldve ruined my holiday, so he told me he wasnt going to defect me, fined me $104 and told me to go put a silencer on it.
Sucks because i live opposite of a police station and they dont give a crap, but i guess its better than a defect. So my moral of the story is, im going to change the exhaust, pay the fine and never drive anywhere close to liverpool at all during holiday periods! :D
https://www.sau.com.au/forums/topic/55112-cops/page/3/#findComment-1149257
He basically heard the car at idle and said it was too loud. He fined me for 'insufficient silencing'.
I suppose i could dispute it because how would he know its too loud if it wasnt tested, but id rather just forget about it.
https://www.sau.com.au/forums/topic/55112-cops/page/3/#findComment-1152628
If you dont dispute it and try and clear your name then it will always be on your record.
Thats one of the reasons why I took the speeding fine to court. From now on I will always question my rights if police are trying to get me woth something.
https://www.sau.com.au/forums/topic/55112-cops/page/3/#findComment-1152835
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
