I can only speak from experience of my R32 GT-R.
Wind in as much castor & camber as the adjustments will allow (Which isn't much)
Make sure you get all four wheels aligned.
Use the standard toe in measurements at the rear and half what Nissan recommend at the front.
This should reduce understeer slightly, give you a reasonably secure back end for the turn in and grip the car up through the corner.
im no expert...
the more camber and/or toe you put on for better performance expect to loose out on tyre wear.. depends what you want more, handling or tyre wear...
handling - ie track, then as much neg camber as you can
put as much postive castor on as you can as well...
toe i've been told to stay pretty neutral, think i have a tiny bit of toe on the rear, none on the front.
The car should have around 2.0 - 2.5 degrees neg camber as standard on the rear and 1.5 - 2.0 degrees neg camber on the front. For optimum tyre wear you want around 5.0 mm total toe in on the rear and 3.0 - 4.0 mm toe in on the front. Providing that your camber specs are around these figures. It will change depending on the camber values and depending on your suspension set up. For the track you want almost no toe in on the front and around 2.0-3.0mm toe in on the rear. Don't play around with the castor if you can help it. but if you have to, you can wind it forward as far as will go and it should increase steering stability in general. Make sure though, that if you do this that the castor is set up half a degree higher on the left, sometimes three quarters of a degree higher. You should expect to pay around 60-70 dollars for this type of four wheel alignment and make sure you watch them doing it so they don't do the dodgy on you.
Plus, if you have a huge exhaust, sometimes they can interfere with the Left rear rack end and burnt the locking nut tight. Just be prepared for a little extra work if they can't crack it.
post the stats up here when it is done or pm them to me and I will tell you if it was done properly. (I was a Wheel alignment technician for 6 years)
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
