hey guyz im just asking a question on behalf of my mate, he has a auto 1995 r33 with a fmic and he is wanting to make more power out of it with the usual mods exhaust, fuel pump etc but he was wondering how strong the auto box is? stronger then a manual? and if anyone on here has a auto making some power how much and are they reliable?thanx ;)
https://www.sau.com.au/forums/topic/55159-auto-reliability/
my lines auto and pullin 208.9rwkw and like my number plates suggest it gets kicked in the guts every day
the only things that are wrong with mine are
coilpacks
ignitor coil
starter motor
alternator
oxygen sensor
(((((Think it was struck by lightning))))) jokin just a lemon
but except for the coilpacks and ignitor coil these are pretty auto unrelated problems
that will be fixed on tuesday
i am also curious about the spool up in snow
i usually rev it upto about 5000rpm in nutrual the slam it into first
but only in the wet or when racing and only cause i can get a replacement gearbox for free
https://www.sau.com.au/forums/topic/55159-auto-reliability/#findComment-1077408
My auto is running strong at 200rwkw.
For serious questions about whats possible and how it should be done, ring MV Automatics in Adelaide. They added a trans cooler and shift kit to my auto and gave me the impression they were good for close to 300rwkw. There are mods you can do if you are running an auto with over 300rwkw.
https://www.sau.com.au/forums/topic/55159-auto-reliability/#findComment-1077725
Did your car come with a transcooler? or did you just upgrade to a bigger one?
What did the shift kit contain btw?
https://www.sau.com.au/forums/topic/55159-auto-reliability/#findComment-1077811
Lukits01 - yes my car came with a cooler, but I had a bigger on installed. (like the standard intercooler but on the drivers side)
I am not sure what the shift kit contained as it was purchased and installed by MV automatics. Shifts are now a lot tighter when under acceleration, and the tyres chirp during gear changes.
https://www.sau.com.au/forums/topic/55159-auto-reliability/#findComment-1077951
yea i have found that a big trans cooler makes the world of diffrence my R32 did not have one it just cooled through the radiator piss poor. My R33 all ready has one but it's so small i will be changing it out next week i will be expecting the same change
https://www.sau.com.au/forums/topic/55159-auto-reliability/#findComment-1077965
Push the snow button put food on the brake and stall it up - wheels wont spin because its in second gear and when your ready to take off press power and let go of the brake at the same time time and you get some interesting launch's :D usually wheel spins off the mark dont do it too much cos the clutch packs dont like it (As i found out)
I put a 5 speed in it after it blew up and never looked back.. even though im having troubles now as the Pedal box broke under the clutch cos of sydney traffic and a heavy clutch.
But yeah cars i was just beating before in the auto - I was smashing them in the 5 speed - remember that auto dif ratio's are 4.39:1 where manual is 4.11:1 so you will be quicker off the mark then the 5 speed released skylines.
https://www.sau.com.au/forums/topic/55159-auto-reliability/#findComment-1077969
A good auto will still change gears faster than a manual, and will consistently do it at the correct RPM. Giver a choice and all things being equal the auto should always beat a manual.
NB - I am assuming the manual has an upgraded clutch and the auto has had a shift kit, and that both cars have similar power.
https://www.sau.com.au/forums/topic/55159-auto-reliability/#findComment-1078154
Changed automatic fluid today, car feels alot smoother and a little faster :)
it took me awhile cos i took the transmission cooler off and gave a full degrease, flush and replaced all the rubber hoses.
I removed the in pipe from the cooler and attached a length of hose, then turned car on and watched it spray out :(
Fluid was horrible! When i check it every now and then with the dipstick its been a perfect pink color, but once it was out in a bucket it turned out to be a brown color (not because of the color of the bucket :( )
I managed to drain 4L on the dot, going to redrain again next week.
Used castrol transmax z $59 per 4L :kick:
https://www.sau.com.au/forums/topic/55159-auto-reliability/#findComment-1079619
    • You beat me to it, I was going to say this -  And this -  Sounds like things are coming along pretty well and your learning heaps along the way.
    • It's the same ABS unit from the old shell.  It was all just lifted and shifted.  I am looking at the BMW MK60 ABS unit as a budget upgrade, as I'm not keen on handing over 15k for a Bosch unit.
    • Bear in mind RBs tend to be pretty terrible for fuel economy and it heavily depends on driving style. In my experience with a heavy-ass turbo Stagea the 10l/100km is really just ideal conditions highway driving. Start-stop in the city is killer and it ends up being 16-19l/100km easily. I keep track of it every time I get fuel and it is never pretty. There are a few topics in the forums where people share their fuel economy if you want to get some ideas of what it can be like. I don't think it is worth that much to compare though because it depends so much on the driving.
    • R32 HICAS, so long as the CU is not itself faulty, is easy to keep working enough for the PS. Just unplug the smaller of the two loom plugs, on the CU, like I have already said about 4000 times on this forum. This works with all the stock hardware, or with a lock bar, or with a complete removal. I know, because I have done all of them. OK, actually, I never put a lock bar on because why would you put a lock bar on when you can get rid of the whole lot, including the stupid tie rod ends?
    • Join the NorCal facebook group btw, but if you can confirm it is HICAS I would install a lock bar and do the work to keep the HICAS control unit happy despite the hardware not functioning. The HICAS control unit is also responsible for speed sensitive power steering so if it's unhappy you'll get failsafe/heavy power steering. A standalone can control that power steering solenoid valve but sometimes it's just easier to stick with the factory setup. Tomei makes a little electronic module that you can install to fool the control unit. I would probably go through the effort to not use a scotch-lok and build a harness so I don't have to chop up the OEM harness. Where you could source those connectors and pins I wouldn't know at the moment though.
