Hi guys,
Going to buy a Greddy plenum for the RB25 for simplicity of pipe work. In addition to my list below, what is involved in changing the plenum?
New gasket
Throttle cable modification (any recommendations?)
Throttle body adaptor
Water and vacum line extension?
Cheers
https://www.sau.com.au/forums/topic/55166-rb25det-greddy-plenum/
  • Replies 59
hey gtst89, i will also be doing the same sometime in dec (will be doing it with fmic) with the Throttle body adaptor u can buy the kit with the plenum to suit the r33 rb25, or else i belived a Q45 throttle body will fit perfectly.
Water and vacim lines, if need to be extened is easy as going to buy the lines from autoshop (i guess it is the same stuff i use when i did my ebc)
I am also interested in the throttle cable mods :confused:
cheers mike
Hi guys,
New gasket
Cheers
You have to either make up a Throttle bracket and get a longer throttle cable, I have found going to a wreckers yard and getting an older model Nissan pintara cable works great. You also have to extend to connectors as they don't reach under the plenum to connect onto things like the AAC valve, so if you’re experienced in extending connections that shouldn't be a problem. Vacuum and water lines, only need to be trimmed up to fit. They are simple. Apart from that, theirs nothing else really to it.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
