Nice!
Got similiar parts installed on my car already except turbo is a Garrett GT35 and boost controller is HKS EVC 3.
Do the internals first before it blows and save youself alot of labour costs from getting everything installed and then removed to get the internals done later.
Have YOU done your internals?
  • Replies 91
and youve got a GT35 inasnt?
:D dont make me laugh. You aint got a GT35 and you know it.
b33st - you can use RB26 rods, $400 and prepping.
I've got em in mine, and a lot of people do it as 26 rods are pretty decent for the buying price
:)   dont make me laugh. You aint got a GT35 and you know it.
GT30 Actually, i was flying over perth when i typed that :)
Ok i've decided to be a little more patient and wait till i got the cash and do internals properly at the same time. Looking at forged rods (crower), Pistons (venolia) looking for people opinions on this. Also What rings, bearings, headgaskets (brands, thinknesses) are people using. Crank i am just looking at balancing and probably nitrating.
Plan is to buy parts then get someone to bolt the engine together for me.
  • 3 months later...
OK i've held off a little but and gone the whole hog. Going to it properly and all at once, internals and all. Have perchased venolia 20 thou over pistons and am now about to purchase a set of rods.
i have priced up the following.
Crower $2100
Argo $2300
Par $1800
I personally am leaning towards the par one's as the price is good. Any one used these or have an opinion on them.?
  • 1 month later...
Starting to get somewhere now. After 2 years of buying bits and pieces work has actually started on the car. Just finished lifting the engine out now. Was going the spend the day stripping it down but had no bolts long enough to attach it to the engine stand.
Got her on the stand and stripped down today. Bores look perfect!
I am away on holidays next week for a few weeks then it's time to get some machine work done. Will probably get the head sorted first, just a mild port new and some stiffer springs. Not too sure if i will do the valves too.
  • 2 months later...
Engine is at the Machine shop now.
Head is getting ported, tomei springs and cams
block getting bored, honed and o-ringed.
Everything is to be balanced (standard crank, Argo Rods, Venolia pistons),
using ARP Head stud kit and standard thickness copper head gasket and ACL Bearings.
  • 4 months later...
Time for another update.
My Engine is now completed and will be picking it up from the engine builder some time this week if i can find the time.
I ended up shelving my Venolia pistons as didn't want to run the clearances that they specified and also wanted to drop the comp at little, CP pistons have gone in in their place.
Also didnt go with the copper gasket just a cometic MLS.
Heads ported, new tomei cams and springs, new guides also but reused the standard valves.
I can't belive this is taking so long but at least it is progressing. I just hope i'm back on the road by christmas.
Edited by B33st
    • It's impossible to convey what it will feel like to get the right torque. But you can develop a feel for it. A 900mm breaker bar is.....f**king huge. I only use a normal ~400mm one. But with 900mm being very nearly a metre, and the right torque being in the order of 100Nm, then you're going to need a bit over 100N of force, which is about 10 kg. So if you practice using the bar pulling up, instead of pushing down, then it will be about the same effort as lifting a 10kg bucket of water. That's what the pressure against your fingers should feel like. Ish. If you use a more typical length breaker, then it's about twice that. So a good 20 litre bucket, or a little bit more.
    • Also, if anyone has a torque wrench around Williams Landing area and can lend it to me for like 5 mins - I got 4 bottles of Furphy left and I’ll throw that in with a Happy meal 😂
    • So today I decided to bleed my brake fluid, which meant to the wheels came off the car at my garage for the first time. I only had a 90cm breaker bar with me and I noticed that some 1 or 2 lug nuts were a bit hard to get loose (from when the shop did the coilovers) Now.... when it came to putting them back on, I didn't want to put all my weight and overtighten them. So I hand tightened as much as possible and then put normal pressure on the edge of the breaker bar and tightened it until I couldn't turn it anymore without putting in an effort. Do you think that is tight enough? Or is that still too tight?  They are tighter than finger tight. Last thing I want is to have them strip or warp sh*t. But hard times mean I can't just go down to Supercheap and get a torque wrench 🥺
    • Dunno what to tell you, when I look at it on Consult I can see this warmup timing map kicking in around 40C coolant temp and it sticks around for a while:  At part throttle on the normal base timing map it peaks around ~43 degrees of timing or something like that, this warmup timing map drops it to like 12-15 degrees.
    • I don't think that's what you're seeing. Something else doing that. The only time I've seen it get so retarded is when it's trying to control idle (in which case we're not talking about mapped timing tagets anyway) and when there is an extreme coolant temperature sensor fault. The RB26 ECU is essentially the same as the 20 ECU and I knew that ging inside out. There is no facility for it to retard that heavily on cold start. The OEMs never used to do it back then. I mean, shit, the catalyst is abotu 3 miles down the exhaust anyway. Early light-off was just a twinkle in some EPA arsehole's eye back then, not a regular engine control strategy.
