Nice!
Got similiar parts installed on my car already except turbo is a Garrett GT35 and boost controller is HKS EVC 3.
Do the internals first before it blows and save youself alot of labour costs from getting everything installed and then removed to get the internals done later.
Have YOU done your internals?
  • Replies 91
and youve got a GT35 inasnt?
:D dont make me laugh. You aint got a GT35 and you know it.
b33st - you can use RB26 rods, $400 and prepping.
I've got em in mine, and a lot of people do it as 26 rods are pretty decent for the buying price
:)   dont make me laugh. You aint got a GT35 and you know it.
GT30 Actually, i was flying over perth when i typed that :)
Ok i've decided to be a little more patient and wait till i got the cash and do internals properly at the same time. Looking at forged rods (crower), Pistons (venolia) looking for people opinions on this. Also What rings, bearings, headgaskets (brands, thinknesses) are people using. Crank i am just looking at balancing and probably nitrating.
Plan is to buy parts then get someone to bolt the engine together for me.
  • 3 months later...
OK i've held off a little but and gone the whole hog. Going to it properly and all at once, internals and all. Have perchased venolia 20 thou over pistons and am now about to purchase a set of rods.
i have priced up the following.
Crower $2100
Argo $2300
Par $1800
I personally am leaning towards the par one's as the price is good. Any one used these or have an opinion on them.?
  • 1 month later...
Starting to get somewhere now. After 2 years of buying bits and pieces work has actually started on the car. Just finished lifting the engine out now. Was going the spend the day stripping it down but had no bolts long enough to attach it to the engine stand.
Got her on the stand and stripped down today. Bores look perfect!
I am away on holidays next week for a few weeks then it's time to get some machine work done. Will probably get the head sorted first, just a mild port new and some stiffer springs. Not too sure if i will do the valves too.
  • 2 months later...
Engine is at the Machine shop now.
Head is getting ported, tomei springs and cams
block getting bored, honed and o-ringed.
Everything is to be balanced (standard crank, Argo Rods, Venolia pistons),
using ARP Head stud kit and standard thickness copper head gasket and ACL Bearings.
  • 4 months later...
Time for another update.
My Engine is now completed and will be picking it up from the engine builder some time this week if i can find the time.
I ended up shelving my Venolia pistons as didn't want to run the clearances that they specified and also wanted to drop the comp at little, CP pistons have gone in in their place.
Also didnt go with the copper gasket just a cometic MLS.
Heads ported, new tomei cams and springs, new guides also but reused the standard valves.
I can't belive this is taking so long but at least it is progressing. I just hope i'm back on the road by christmas.
Edited by B33st
    • The nissan manual says to change coolant every 2 years. Is this still necessary if you're using coolant like Penrite or nulon which has improved over the years? It says it lasts 500,000km which seems hard to believe lol.
    • According to the Muse website, totally different material. The originals were that horrible solid foam rubber that was used for a lot of rear spoiler/flap things, like on Mitsu Galan GSRs. Heavy, and with enough compressibility/flex that any paint on them would crack fairly quickly. The Muse ones are just ABS, which is obviously similar to GTR lower front lip, etc etc. ABS is a good choice if you have the ability to tool up for it. The only thing better might be TPU-RIM or something equivalent. The TPUs were good. Plenty of flexibility (in twisting, bending, etc) but not really in compression.
    • Update 24/01/2025:    Bought a GReddy/Trust Intercooler (crossflow spec-LS) that was meant for a R33 GTST $871 AUD shipped, and a GReddy Profec boost controller $483 AUD, both brand new from Japan. Being honest, I would've thought the intercooler kit was discontinued but I guess not yet. Decided due to funds + time, I'll stick with a nistune on this stock-ish setup ( stock turbo set to probably 10-12psi ) and have it run cleaner ( suspect the 3" turbo back etc has sh*tted on my economy ) for my trip down south soon for the WSBK. Hopefully I can get it all installed and tuned by then. As for who I am getting it tuned with, I will be going with Toshi, (not hearing back from DVS so scratch that). There is also Birrong Auto but not sure if they do nistune installations and if they even tune it... Otherwise, anyone know where I can get my hands on an aluminium intake/suction pipe for an RB25DET NEO?
    • The german cars I've worked on seem to have that issue(in more than just headlights). Mostly where hot, but also just the insulation hardening and cracking in various places. Not abnormal from what ive seen.
    • According to the Muse website, similar material, but not the same. Meant to help with stopping the paint cracking. In saying that, I had genuine ones on my last grt, and never had that problem.   Could you post pics when you get them? Very much thinking of buying the Muse ones over fibreglass.
