  • Replies 91
CR ended up about .4 below standard so about 8.6.
Went with the ARGO rods and yes 256 poncams with matching springs.
Had Colin lloyd (Headsense) do the head work as well as machine and assemble the engine. Hopefully i can find the time to complete the rest at home with the help of my old man.
A break down of the costs involved with the engine build for those interested.
CP pistons $1185
Rings $275
Straighten & Polish Crank $182
Bore & hone block $188
Deck Block $110
Balance $ 267
Overhaul head $590
Porting $810
New guides $237
Cometic gasket $362
Big end bearings (ACL race) $89
Main bearing (King) $72
Gaskets etc. $28
Assembly $880
Total $5275
CP pistons $1185
Rings $275
Deck Block $110
Balance $ 267
Overhaul head $590
Porting $810
New guides $237
Cometic gasket $362
Gaskets etc. $28
Assembly $880
Total $5275
Thats a good price all up, where abouts did you get the work done?
Headsense (colin lloyd) at coopers plains. My only complaint with him was that it took a while before he got around to actually doing the work, he had my engine there for about 3 months. It's a one man workshop and he's pretty busy.
Yeah getting an engine built can test your patience, what made you choose him?
Does he have ALL the equipment to do the work on site?
Btw nice engine shot, looks really clean!
I went with him as previously i was getting most stuff done by Hardcore at slacks creek and i found out that he was the one that was doing all the headwork / machining for them so pretty much went straight to the source. He's pretty well known in drag racing circles and has been supercomp champion a few times now racing his own cars, you'll see his name across the top of the main stand at willowbank.
Putting the rest together and then putting it back in and hooking everything back up is the FUN part! Hooray. Then you will get it tuned and it will kill ya waiting to drive it. Leave the tuner in a nice cloud of white smoke all the way up the street....ohh such a good feeling when you got bulk power on tap :)
Cant wait till you post tuning results.
Still undecided with the tuning side of things. It will either be FIST performance or Mercury Motorsport. FIST have done all the work on my old mans XR6 turbo and they've looked after him very well but Mercury seem to have a better reputation around here.
I sent the plenum and rocker covers to be powder coated today. Have gone with gold for the rocker covers and textured black for them plenum. Pictures will be posted when i get them back. Hopefully they look ok.
powder coated hey. I know some people who hpc coat them...comes up pretty good. should look very nice.
Also mate, just wondering where did u find your v8 throttle body for the plenum. I could not for the life of me find one anywhere, and had to machine up an adapter plate to suit the std TB. Cheers.
Edited by r33_racer
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
