  • Replies 91
CR ended up about .4 below standard so about 8.6.
Went with the ARGO rods and yes 256 poncams with matching springs.
Had Colin lloyd (Headsense) do the head work as well as machine and assemble the engine. Hopefully i can find the time to complete the rest at home with the help of my old man.
A break down of the costs involved with the engine build for those interested.
CP pistons $1185
Rings $275
Straighten & Polish Crank $182
Bore & hone block $188
Deck Block $110
Balance $ 267
Overhaul head $590
Porting $810
New guides $237
Cometic gasket $362
Big end bearings (ACL race) $89
Main bearing (King) $72
Gaskets etc. $28
Assembly $880
Total $5275
CP pistons $1185
Rings $275
Deck Block $110
Balance $ 267
Overhaul head $590
Porting $810
New guides $237
Cometic gasket $362
Gaskets etc. $28
Assembly $880
Total $5275
Thats a good price all up, where abouts did you get the work done?
Headsense (colin lloyd) at coopers plains. My only complaint with him was that it took a while before he got around to actually doing the work, he had my engine there for about 3 months. It's a one man workshop and he's pretty busy.
Yeah getting an engine built can test your patience, what made you choose him?
Does he have ALL the equipment to do the work on site?
Btw nice engine shot, looks really clean!
I went with him as previously i was getting most stuff done by Hardcore at slacks creek and i found out that he was the one that was doing all the headwork / machining for them so pretty much went straight to the source. He's pretty well known in drag racing circles and has been supercomp champion a few times now racing his own cars, you'll see his name across the top of the main stand at willowbank.
Putting the rest together and then putting it back in and hooking everything back up is the FUN part! Hooray. Then you will get it tuned and it will kill ya waiting to drive it. Leave the tuner in a nice cloud of white smoke all the way up the street....ohh such a good feeling when you got bulk power on tap :)
Cant wait till you post tuning results.
Still undecided with the tuning side of things. It will either be FIST performance or Mercury Motorsport. FIST have done all the work on my old mans XR6 turbo and they've looked after him very well but Mercury seem to have a better reputation around here.
I sent the plenum and rocker covers to be powder coated today. Have gone with gold for the rocker covers and textured black for them plenum. Pictures will be posted when i get them back. Hopefully they look ok.
powder coated hey. I know some people who hpc coat them...comes up pretty good. should look very nice.
Also mate, just wondering where did u find your v8 throttle body for the plenum. I could not for the life of me find one anywhere, and had to machine up an adapter plate to suit the std TB. Cheers.
Edited by r33_racer
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
