All,
I have got Bilstein shock absorbers with Pedders springs in my R33 GTST, The car is fairly low which i know it will ride firm but its too bloody firm.. It shakes like crazy over bumps and it also feels dangerous when accelarting over bumps because the back of the car slips around. Would it be the springs or the shock absorbers?
Does anyone know any combination that works well? Should I go for King springs?
Thanks
https://www.sau.com.au/forums/topic/55184-suspension-is-toooooo-firm/
What else is done to the susp?
The fact that it "shakes" suggests to me that the susp could do with a freshen up more then new shocks and springs. I cant see Pedders springs with Bilstein shocks being massivley different to my Bilsteins and Whiteline springs...but i have new bushes throughout my car, and whilst it rides firm the car feels tight, no wabbling/shaking over road irregularities.
As for slipping around over bumps, yo have 250rkws so you will have to learn to show some smarts with the throttle (Come on you drive F3000s:)) that said you should be able to get the thig to ride bumps nicely.
Your welcome to drive my car with a Whiteline setup, but its an R32, but should still give you an idea of the direction they take by way of spring and rebound rates on a sporty road car
Some people who are involved with Bilstein seem to like making them very hard...
I was involved with a race team asking them to make them softer, they came back harder... every time.
yeah maybe its the subframe bushes thats causing vibration, hmmm or maybe its just stiff suspension? is it all the time or is it only under acceleration? maybe your subframe bushes are worn and its causing your diff cradle to vibrate, get some subframe buses however this will stiffing up your rear also but could get rid off this vibration a cheaper option than springs maybe to try first
i also have bilstein shocks, the yellow 'sport' ones from UAS, with king springs, ride is great, definitly not too hard.
You should be able to find out the spring rates from who you bought the springs from. You probably have the same shocks as me, if so its not the shocks. The shaking over bumps could be due to the springs being too firm for the shocks, so that the shock cant control the bump/rebound, and as a result the car get bumpy and loses contact with the road over bumps.
Why did you buy PEDDERS of all springs when theres quality stuff like Kings, Lovells, Whiteline, Eibach etc which if you speak to Bilstein are all highly recomended for use with their shocks?!
ahh the other thing, if your springs are more than 2.5inches lowered, the shocks arent happy, and the ride suffers notably. I ran at just over 3inchs lowered for a while, and after i got sick of the ride and bottoming out i now have 1inch lowered, and the ride is completely improved.
The Pedders springs came with the car... When i say it shakes i mean when you go over bumps the car rides too firm and cause the dash to rattle and just makes for not the most pleasent ride... I think that the shocks may be over damped but it could be that springs are just way to heavy for the shock absorbers.
The car is currently fitted with
*Bilstein Shock Absorbers
*Pedders Lowered Springs
*Whiteline Adjustable Swaybars
*Whiteline Camber Kit Front
*Whiteline Camber Kit Rear x 2
*Whiteline Castor Kit Front
*Whiteline Subframe Align/Lock (Pineapples)
all of which have been fitted within the last 4-6 months so nothing is old and worn out
Im thinking maybe even getting rid of the shock suspension setup all round... New shocks and springs. I had Bilstein shocks on my Formula 3 and they were SHIT. We changed to Penske shock absorbers and only used Eibach springs which we changed for different tracks. But i cant justify spending over $8000 for a suspension setup like so.
All,
Thanks
I have also got Bilstein shocks and had the car prob lower than your at the moment when i first got it. It was ruff as guts until i put in new springs to raise the car as it would get up my driveway, and now rides alot better.
Maybe try out another set of springs coz the shocks might be under constant compression if not setup right.
... but I'm tipping your problem is more likely all the yellow bits. The take all the compliance out that the boys in the backroom at Nissan built in with the rubber bushes.
Now they dont use rubber for its excellent performance and ability to make this go like an F3. They do it to stop all that harshness and to stop your mobile jumping out of the consol.
From our recent research the silver bars are too heavy anyhow... well at least with the current configeration we are running. (And thats good enough to get round Basky in a 61)
Put it up to standard hight and try that matey.
Good luck
I think Roy was angling for a run in the race car... sly bugger. LOL
Gday mate, I am new to this forum stuff, and you sound as if you may be able to help.
I have an R33 gtst. The ride has no give at all, when pushing down on the front and rear i cant even see the car move. I have JIC height adjustables in the rear and OHLINS in the front, I am unsure of the spring manafacturer but the ride is way too hard. I have been told the setup I have is for drifting. In any case i want to sell the setup i have and just have a normal ride without turning my insides out. Any suggestions
HeathGTST, I've got the same setup as you - Pedders springs (Sports ryders) and Bilsteins - although I don't feel they're too hard, it's just that the whole setup is undersprung/overdamped... the effect can almost be as bad as too-hard springs, which I had when first got the car - it had hard-as-rocks Cusco gear in it.
Going to get a quote for a set of King's lows, will post the quote in here when I get it.
I put my money on the Pedders springs being too hard.
Got some for my 4wd recently and WAAAY too hard, long travel ones too! And thats with standard struts.
Yeah yeah I know, totally different to a skyline but I reckon thats
what it would be.
Kings would be more like $400 a set.
Please dont say the Bilsteins are harsh, I'm getting some very soon. :(
Nah, bilsteins are great. I went from pedder springs and 'soft' dampers (KYB excel and Pedders 'Comfort' shocks - this combo wasn't good, it was like being in a boat, going over largish waves, which is why I suspect the springs were/are too soft... when the bilsteins went on, it tightened everything up, still not perfect, but much better.
But no offence, RedRocket, but it makes no sense saying that his problem would be harsh pedders springs because yours on your 4wd are too harsh. Two different cars, different springs, rates, etc. :)
None taken, just saying thats where my money is..
I considered all evidence submitted and concluded that the springs would be the more likely cause out of springs/dampers. Then given my experience with Pedders springs being way too hard for their given application it helped seal the choice! :rofl:
Thought I might cop some flak for saying that...
    • I know this is an old thread but I have a particular attachment to the ENR34, so I don't think additional content hurts. For starters, I agree with everyone here in that the performance of a stock R34 GTR is a pretty low bar and one that you're going to spend a lot of money "matching". Now if you're willing to deviate from that template as your goal, you'll be much better off and enjoy the car much more. The engine in the NA R34s is a real kick in the nuts in terms of upgradability compared to previous generation NA cars. The NA heads on the RB2X NEOs have MUCH smaller intake port cross sections and are not compatible with any of the aftermarket forward-facing manifolds available for the RB25DET. This can be remedied with a RB25DET NEO head, but those are expensive relative to what they are. A full long-block from a turbo AWD Stagea is generally a better value and will run you about $4000 USD to get it to you. This will get you the stronger RB26DETT rods, as well. That would give you a base to build off of to be safe in the 400whp range. Not shooting for the moon, but if the stock R34 was your bar, this engine would buy you enough to be just North of stock GTR power. A forward facing manifold would allow for the easiest method toward using Bosch EV14 format injectors such as those from Injector Dynamics and FIC, to name a couple. People hate them because they're copies, but Greddy fakes can be had for around $300 USD. With what the fuel rail, regulator, injectors, and the rail adds, figure $2000 USD for the whole setup including the manifold. With the OEM brackets and a bit of trimming to the ends of the lower frame rails, the OEM intercooler mounting brackets can be used to mount an OEM GTR intercooler, or an aftermarket one made for a GTR. Those are handy vs a universale due to the angles that the end tanks have on them. Then your plumbing become super straightforward at that point despite having to cut a hole where the battery is an a matching one on the other side for the pipes. Battery can go to the trunk. I'd round up to a healthy $2000 USD here too (maybe even a tiny more) to allow for a nice aftermarket unit and some pipe fabrication. Or if you can find someone that's upgrading to something larger, the used market comes in clutch here for a decent savings. I won't even get into turbo sizing as that's something that would be for yourself to determine. HOWEVER, for the purposes of your stated goals, a Borg Warner 7064 with an internal wastegate would be a perfect spooler and would make stock GTR power easily. It would also bolt up to your OEM manifold (that would come with the DET you purchased a couple steps above) if it were ordered with a T3 flange. More with adequate fuel. If you can stick with the OEM exhaust manifold then expect to be in the whole about $6000 USD for decent turbo like the one suggested, a down pipe, new O2, and full exhaust to mate up, and upgrades to the integrated BOV in an EFR or a standalone BOV for a different turbo, as well as an aftermarket IWG (internal waste gate). Those last two are definitely optional and unnecessary. All of this stuff above does you no good without any way of tuning and or monitoring the engine. Bite the bullet on a standalone engine management solution. If your experience with wiring is limited, you're going to have to hand it off to someone else, though. Unfortunately, the adapter/patch harnesses available are typically made around the GTT which does not include AWD, and the GTR, which integrates into a lot of chassis features that aren't present in your wiring interface. So the ENR34 is the oddball. So you'll want to expand a bit on your selection and find an ECU that's capable of running the ATTESA pump also. I have a Link Thunder, but you don't need quite that much ECU to accommodate that. You WILL need someone with the know-how to tune it and code those features into whatever software it uses. And to wire it up. This will be your most significant expense. Call it $6000 USD with an ECU, an okay wiring job (no motorsport grade at this price), aftermarket triggers and R35 coils, and the time it takes to tune the ECU with added features (electronic boost control solenoid, MAP, IAT, the new triggers, and ATTESA) and don't be surprised if it's more if you want better work done. Grab a clutch made for any RB pull transmission R32/R33GTR made for the power handling capacity you're looking for. Budget $1500 USD for a new good one. That's about $20,000 USD for an engine you've upgraded yourself and had wired and tuned by someone else. That's no brakes (ENR34 brakes are pathetic), suspension (again, pathetic), or wheels and tires. So you're pretty spot on in terms of spending $30,000 USD extra on the car just to get it to perform a little better than a stock R34 GTR while looking like a bone stock ENR34 with some wheels and suspension mods. That doesn't include fluids, maintenance items, gaskets/seals, repairs needed or anything else discovered along the way. But you'll have a car you can take to the track and have fun without worrying as much about nicks and dings.
    • Okay so, please read this. car started and ran fine. got my tuned ecu by RSenthalpy, did a bunch of pulls to test it out and finally drive the car after half a year of it just sitting and idling at most. Everything was good, thing ran flawlessly and had so much power, didn't feel slower than a Prius anymore. Parked it back and turned it off.  Next day, I install an AFR and start the car. Didn't wire anything to the ecu. Just gauge.  Car started, but died out in about a minute. I figured it was cause my car was on a lift and the fuel was really low and old. I add 5 gallons of fuel, still cranks but no start. I remove all AFR wiring (tapped into double din acc and power wires but there was a nest of wiring there so I was worried I messed something up. tried to put it back to how it was prior to afr install.) Still cranks no start. Changed spark plugs with brand new ones Changed fuel pump with a new one (verified working) Did compression test , compression came back all at 150ish. All fuses are good, Relay seemed good but ill double check by switching similar relays around. Verified MAF is working - Ended up getting curious as to why fuel pump is not priming when ignition is on, so I cut the fuel pump ground and power and connected them directly to a portable jumper. I also disconnected fuel line to fuel rail to verify fuel is being sent. So with direct jumper power, the fuel pump turns on and shot gas everywhere through the fuel pipe that I had disconnected, so ny doing that, I verified no clogs in fuel lines or filter. - Tried starting the car with that jumper directly wired to power and ground, but car still did not start. I'm guessing its a CAS issue but im a little scared to check it without messing up timing or anything else since I actually dont understand how to check CAS lol. If anyone has any other suggestions or recommendations , please let me know.
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
