There's a lot of talk everywhere about emissions lately, and even the current model MX5 has dropped a bit of power in order to meet some new emissions standard.
What I want to know is, why are emissions so hard to control? Aren't the "emissions" just unburnt fuel? I would have thought that if you improved the ignition and maybe ran a better quality catalytic converter with a good O2 sensor that it shouldn't matter how much power you're running. If all the fuel is burnt you should in theory be able to run mega horsepower and not worry about emissions.
So anyway, it doesn't seem as simple as that or it wouldn't be such a concern. Can someone explain why it's so hard to control them?
https://www.sau.com.au/forums/topic/5521-emissions/
Hi JimX,
From what I understand, it's not just unburnt fuel. Hydrocarbons, and various other crap are made from the combustion of the engine. Usually unburnt fuel isn't so much of a problem. Also remembe rthat as you car developes more power, you are creating more waste. High fuel usage simply make more crap.
In Japan, emission testing is done at low RPM and load, so even poorly tuned cars can pass. In Australia, the testing of emissions is extremely strict, therefore your car needs to be in good tune before it will pass.
With regards to emissions being hard to control their are, all new engine have (usually) very high levels of compromise (sp?) to accomodate NVH and emissions. They are also much better desinged, so we usually see a better engine anyway.
If you take a look very *very* serious drag cars etc, the will usually modify the engineering extensively, as they have no need for emissions control, road reg etc.
In the end, having a car tuned properly, with a new or clean cat. should pass all emissions.
Some of this stuff is very general, and or slightly wrong, feel free to correct me.
Regards,
Tim
https://www.sau.com.au/forums/topic/5521-emissions/#findComment-84093
Its really about the products of the combustion process. Ideally, when you burn gasoline - which is basically carbon and hydrogen - you should get CO2 and Water as the products. However, if you burn it in the presence of Nitrogen (which is 80% of air), then you get oxides of nitrogen (NOx) which is ultimately responsible for smog. And the spark that ignites the air/fuel mixture can cause the oxygen to convert to ozone.
Other chemical, rather than combustion, reactions occur, producing nasties like benzene.
If the fuel mixture is too rich (not enough oxygen) then you get CO instead of CO2.
Then you add in impurities in the gasoline like sulphur compounds, which undergo changes to produce oxides of sulphur (SOx), which can dissolve in water to produce sulphuric acid ("acid rain").
The catalytic converter is primarily there to chemically alter the NOx and SOx compounds.
So you see, its a lot more complicated than simply controlling the amount of unburnt fuel coming out the exhaust pipe.
https://www.sau.com.au/forums/topic/5521-emissions/#findComment-84644
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
