hahah that was sooo funny... then we got him to yell out "dan the man rules" :( over all i think it was a great night.. so many adventures and just chillin inthe grandstand was hella cool.
Thanks to Liz and Dan for hanging out with us :) and nice to see you again lauren. and nice to meet u melki and adrian :(
Break It Down Now!!
  • Replies 416
a siikass of a night!!!
Checked out all rooms early then hung around the middle-ish area of the main room until around 6am then checked out the rest of the rooms again, only to find adrian_perth gurning it out in the drum and bass :cheers:
Man did Ferry's set go off or what? especially when he played his classics, Punk and ROck Your Body Rock... that was absolutely awesome!
Nice to meet u Niz and Melki ;), hope to meet the rest of u's soon ^^/
I went totaly nuts to 'Punk' and 'Rock Your Body' was aiting all night for them to play, i as outside on the stadium when 'Punk' started, was pretty crazy sight seeing basically the whole audience in the stadium pick and and move inside to listen. And then 'Rock Your Body' came on directly after wards, total highlight of the night.
Luv'd seeing a strobe light go off and a good song come on, 1000's of people put the hands up and start jumping.
Its insane.
:jump:
:rave:
I like repeditive music, I like repeditive music,I like repeditive music, I like repeditive music, I like repeditive music, I like repeditive music, I like repeditive music, I like repeditive music, I like repeditive music, I like repeditive music, I like repeditive music, I like repeditive music, I like repeditive music -Regurgitator :cheers:
The Panics are good ;)
Had a great time :) Saw Adrian, Petie pie, Lozzle, Tigeryas, BamBam, Liz n Dan, Boosty n Denish, Denver ...... to those i missed damn! :)
Had a great time .... spent a lot of it upstairs hanging out with Mel, Josh n Darrens funky clone. Tao's remix to Smells like Teen Spirit went crazy :crazy:
Pulled up fine Sunday morning ..... then got a bit pissed on sunday night and now i feel dizzy and shite .... so today at work will be interesting.
Hey mel ...... foreeevver young ... i wanna be foreeever young :D *rofl*
was wicked fun! outside was such a nice night.. funny watching the volleyball.. bring on bikini's! they rock.. got so hot so ripped off shirt and ran around with a glowing green bikini top on.. felt so much better after that.. :)
was good fun night. nice change from metros and monkey bar :)
adam f goes off!!! :D
well i had a ball runnin round with my lil sis and a few old rave buddies i met along the way mr lion was a hit with the ladies involving many hugs for both of us bring on cute backpacks tunes where great as you would expect for a belmont rave and the atmosphere was brilliant good ta see perth can still bring it for the big ones
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
