Hi,
As some of you may know from my other thread, I am having some trouble with a R32 front cut ...
I did a compression test 2nite, and was a little suprised with the results... so repeated the test 3 times with exactly the same results.... The motor only has 119000k on it.....
Results are ...
1 - 150
2 - 145
3 - 145
4 - 130
5 - 135
6 - 150
The cut has a 3 month warrenty... i've only had it a week, and have not made much inroads into stripping it... what do you all think? Call them and take it back?
Please help! :)
was cold..... hmmm maybe i should put it all back together and warm it up :)
is it really meangingless tho ? not even an indication of internal health ? :confused:
I dont worry too much about the pressures, is your gauge calibrated...been dropped lately, read accurately in the first place?
Just go on the variation between the cylinders. Cylinders 4 & 5 look a little low, but i doubt they are low enough to justify replacement?!?!!?!?! Still mine read a lot closer then that when i had done 155,000kms on my RB20
The variation is a little on the high side but i doupt they will take it back .
Its a second hand engine they will say to you ,what do you expect .
If you check with the nissan workshop manual , difference between cil limit is 14 psi so its almost to specs limit . Well number 4 is out by a little more that that .
Anyway you can try and see what they will say .
how many rev's have you tested it at its maby a good thing to count them as cheep comp testers keep presuring up and down as thier internals arnt so great in conclusion your test readings are not so bad if say in cylinder 1 you did 7revs and 4 did 5revs this could be your issue also warm your engine up before hand it will make a diffrents
All I did was turn it over until the guage stopped moving... I did not do the same on all.. I was not counting.... just stopped when the guage stopped
I will do it at running temp.. see what I get then... I cant see how it will make a huge diff....
:coffee:
plugs looked fine...
well....................alrighty then!!!
it will do you no harm asking/telling your mechanic of your issue, (and I understand that it can be an emotional one!!), see what he says about it.
(the guy u bought the engine off, or whatever).
Do your 'warm test' though, as your fellow Skliner's suggest, first up.
I know how you feel, but your baby will be fine!!! (got heaps of life left in the thing!!)
Remember Ed G......the test between a truly warm/hot engine and a cold one can be quite dynamic!! That's just the way they work!!
ah.......anyways!!!
Mark :)
Yeah...just stressin!!
I'mnot going to call the dude until after I have done the warm test.... doing it 2moro (just put it all back together)
The motor is smooth tho, no knocks/clicks/taps etc, so just hoping for the best 2moro... Will post up the results!
I hope its ok!
The difference between ring end gap from a warm to cold RB20 is around 10 thou, so YES...this will make a difference. Also, have you done a wet compression test. This will give you a true indication of whether the rings are bad. All you gotta do is a normal pressure test, then pour about 2 capfulls of oil down the sparkplug hole and do the cylinder again. Note the new readings and then post them hear. I will tell you if the rings appear stuffed.
NO QUESTIONS...JUST DO IT!
2 Cap Fulls?!?!?! Thats quite a lot... :D
My RB20t when I pulled it out had 140 all round with 5psi variation +-.
I would have loved to see how much more it had left in it. I pulled it out at 169,000km's.
Its only ever run the stocker turbo on 1-1.1bar though. :)
There was a tinny little bit of oil that had coated the inside of all the piping but it was really stuff all. Probably just a build up over time.
I hope its ok!
Motor is smooth, no knocking, idles ok? ROSES!
there you go!
Do not pour oil down your sparky holes!!! Not a drop!
Like mentioned, comp lock can and will (to some degree) occur.
Just wait and do what you said you were going to do for now. 'Wet test' (if you feel you really have to) later.???????
idle is not ok :D see other thread .. uhh will find the link...
Will do warm test... post then wet test if needed .... what does the wet test prove that a 'dry' test wont?? :confused:
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
