Hi,
As some of you may know from my other thread, I am having some trouble with a R32 front cut ...
I did a compression test 2nite, and was a little suprised with the results... so repeated the test 3 times with exactly the same results.... The motor only has 119000k on it.....
Results are ...
1 - 150
2 - 145
3 - 145
4 - 130
5 - 135
6 - 150
The cut has a 3 month warrenty... i've only had it a week, and have not made much inroads into stripping it... what do you all think? Call them and take it back?
Please help! :)
was cold..... hmmm maybe i should put it all back together and warm it up :)
is it really meangingless tho ? not even an indication of internal health ? :confused:
I dont worry too much about the pressures, is your gauge calibrated...been dropped lately, read accurately in the first place?
Just go on the variation between the cylinders. Cylinders 4 & 5 look a little low, but i doubt they are low enough to justify replacement?!?!!?!?! Still mine read a lot closer then that when i had done 155,000kms on my RB20
The variation is a little on the high side but i doupt they will take it back .
Its a second hand engine they will say to you ,what do you expect .
If you check with the nissan workshop manual , difference between cil limit is 14 psi so its almost to specs limit . Well number 4 is out by a little more that that .
Anyway you can try and see what they will say .
how many rev's have you tested it at its maby a good thing to count them as cheep comp testers keep presuring up and down as thier internals arnt so great in conclusion your test readings are not so bad if say in cylinder 1 you did 7revs and 4 did 5revs this could be your issue also warm your engine up before hand it will make a diffrents
All I did was turn it over until the guage stopped moving... I did not do the same on all.. I was not counting.... just stopped when the guage stopped
I will do it at running temp.. see what I get then... I cant see how it will make a huge diff....
:coffee:
plugs looked fine...
well....................alrighty then!!!
it will do you no harm asking/telling your mechanic of your issue, (and I understand that it can be an emotional one!!), see what he says about it.
(the guy u bought the engine off, or whatever).
Do your 'warm test' though, as your fellow Skliner's suggest, first up.
I know how you feel, but your baby will be fine!!! (got heaps of life left in the thing!!)
Remember Ed G......the test between a truly warm/hot engine and a cold one can be quite dynamic!! That's just the way they work!!
ah.......anyways!!!
Mark :)
Yeah...just stressin!!
I'mnot going to call the dude until after I have done the warm test.... doing it 2moro (just put it all back together)
The motor is smooth tho, no knocks/clicks/taps etc, so just hoping for the best 2moro... Will post up the results!
I hope its ok!
The difference between ring end gap from a warm to cold RB20 is around 10 thou, so YES...this will make a difference. Also, have you done a wet compression test. This will give you a true indication of whether the rings are bad. All you gotta do is a normal pressure test, then pour about 2 capfulls of oil down the sparkplug hole and do the cylinder again. Note the new readings and then post them hear. I will tell you if the rings appear stuffed.
NO QUESTIONS...JUST DO IT!
2 Cap Fulls?!?!?! Thats quite a lot... :D
My RB20t when I pulled it out had 140 all round with 5psi variation +-.
I would have loved to see how much more it had left in it. I pulled it out at 169,000km's.
Its only ever run the stocker turbo on 1-1.1bar though. :)
There was a tinny little bit of oil that had coated the inside of all the piping but it was really stuff all. Probably just a build up over time.
I hope its ok!
Motor is smooth, no knocking, idles ok? ROSES!
there you go!
Do not pour oil down your sparky holes!!! Not a drop!
Like mentioned, comp lock can and will (to some degree) occur.
Just wait and do what you said you were going to do for now. 'Wet test' (if you feel you really have to) later.???????
idle is not ok :D see other thread .. uhh will find the link...
Will do warm test... post then wet test if needed .... what does the wet test prove that a 'dry' test wont?? :confused:
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
