Hi all
I have the opportunity buy 2x 12'' subs in a box. The subs are Cerwin Vega S12.4 and the guy wants $200. Is this a good deal or not? How much would u expect to pay for these 2nd hand?
Specs are:
Power Handling :250 watts (nominal),500 watts (max)
Frequency Response : 30 Hz - 500 Hz
Sensitivity : 95 db
Mounting Diameter : 11" (27.94 cm)
I seriously dont know anything about audio and did a search but not much info?
Dont want to spend alot on audio right now so what kind of additional things would i need to buy to hook this up to my fairly stock r34 system (stock as in clarion/addzest HU + stock speakers i think lolz? What amps etc?
I was originally goin to goto autobarn or something and buy the 2x12'' pioneer ones preboxed for $559 or something.
I just want something which will give me some/fair bit of bass when i listen to my music but nothing overboard
Thanks All
https://www.sau.com.au/forums/topic/55247-subs-help/
its a good price... dont know much about those speakers in particular but 250 watts RMS is decent power for a $200 subr set. Worst case scenario, if you blow the subs, you can keep the box and simply replace em.
For an amp i think 2 * 300watt RMS amp will be the most you should be looking for and would accomodate and changes later on. A weaker amp would work well for those subs... ive seen quite a few 150-200 watt 2 channel RMS amplifiers around.
Besides an amp, you'll need a wiring kit if you dont already have one which can set you back anywhere between $50 to $200 depending and brand/quality/power rating...
im currently using an 1200 watt kit which i picked up for $40... works perfectly.
I actually have a 12inch pioneer in my boot... running 600watts off my amp and with my setup i have no dramas...
https://www.sau.com.au/forums/topic/55247-subs-help/#findComment-1078187
Say goodbye to the entirety of your bootspace though. I have one boxed 12 in my boot and it takes up just on half the boot space. Then mounting the amp as well leaves even less space.
As for quality recommendations on the brand i'd say www.caraudioaustralia.com would be your best bet.
https://www.sau.com.au/forums/topic/55247-subs-help/#findComment-1078238
thanx all
in regards to the amps.. imma bit lost in regards to brands and such..
should i keep a look out for 2nd hand amps or should i just goto strathfield and pick up a 1000W boss amp for $189 (for the time being)?
For $189, it seems pretty cheap even if it stuffs up. lol
https://www.sau.com.au/forums/topic/55247-subs-help/#findComment-1078291
if its only for the time being then it will do fine...
i personally dont see anything wrong with buying a good quality second hand amp but buying a cheaper new one may save you some hassels...
boss isnt a highly recommended brand, and i personally prefer good quality amps which i know will last me in the long run. But a 1000watt amp with that price is pretty cheap...
what are its specs?? Number of channels, features...RMS power etc
https://www.sau.com.au/forums/topic/55247-subs-help/#findComment-1078302
its a 4 channel 1000w amp
4 x 250 Watts max. output power
4, 3 or 2 channel bridgeable
would this run the subs? or should i get a mono block (i heard) or 2 channel (i have no idea)
like i said, only for time being until i get some funds, just dont want the subs to be lying around
I also have an orion cobalt co430 lying around.. its a 4 channel but i dont know the output
https://www.sau.com.au/forums/topic/55247-subs-help/#findComment-1078313
the amp would run the subs well... you would be able to bridge it to 2 channels (2 * 500watts) and that would run em perfectly.
But you must also know, Max output power is one thing, RMS power is another. You should check that the RMS power of the amp when bridged adds up approximately to what the RMS rating of the subs is.
But as far as i can gather, the amp should do well
https://www.sau.com.au/forums/topic/55247-subs-help/#findComment-1078352
dont buy the boss amp. its SHIT. if u want one then i'll sell u my 1200 **MAX** power boss amp for that price. its less then 3 months old with an extended 2 year warranty. Dont buy anything from strathfield. expecially bos. all there stuff is SHIT. ive had two boss subs blow up because the boss amp is basikally drawin "dirty" power. Boss amps are bs because at high power they basikalli bypass their amplifying power and are more or less drawing power direct from the battery. All this stuff was quoted directly from alberts because i had them check the system out. and they know their stuff. Also strathfield fulli ***d me around when i tried to claim my warranty. they said they tested the amp out back and it worked fine when i had it tested 20 minutes earlier at alberts who said the amp was ***d. they wouldnt let me out back to prove the amp was fine and scheduled a a time for me to see that the amp was workin. the time was sheduled for TWO weeks later and i would have to pay for that as well. as u can see, i haf it in for strathfield.....
my 2 cents
https://www.sau.com.au/forums/topic/55247-subs-help/#findComment-1078370
damn... sounds like you've had some bad experiences. I still stand by my statement that i would rather recommend a better brand amp but i cant imagine the boss blowing a fuse running those two subs. Are they really that bad?
I agree the strathfield are a bunch of wankers... wanted to charge me $120 bucks for the same wiring kit i paid $40 for, from a friend. They'll rip you off 5 times before you even buy something.
https://www.sau.com.au/forums/topic/55247-subs-help/#findComment-1078392
thanks for your help guys
one last q.. the guy said the box fits a 180sx and silvias, will this fit a r34 also? i think they are roughly same size?
https://www.sau.com.au/forums/topic/55247-subs-help/#findComment-1078550
I would imagine it would fit in a R34 no probs if it can fit into a 180SX.
https://www.sau.com.au/forums/topic/55247-subs-help/#findComment-1078557
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
