  • Replies 85
whos the dude on here who just got a GTRS tuned on a 33? he got i think just over 250rwkw on 1bar, so i think there should definitly be more in it with more boost, which would put it quite ahead of the 2530- which is a good solid street turbo, which can only be faulted for running out of a bit of puff at the very top end.
For the price of the GTRS's at the moment they are a steal.
There seems to be lots of support for the 30xx series, looking at dyno runs the power looks like a light switch (i even think the 2835 looks to come on pretty hard) are these really good for the street? surely 3rd gear would bag street tyres just coming onto boost, let alone trying to accelerate hard in 1st or 2nd? Sounds like fun, but frustrating when lesser powered cars beat you to 100!
I have a 2835proS on the way at the moment. Going to have to run R-compounds full time, as the 2530 already fries tyres with its paltry 220rwkw! :)
building a RB25DET with a TD06-25G, nice laggy turbo with good topend power, and a misfiring system to keep the turbo spooling while I'm off the throttle. The one that I've bought is a metal sleeve thingamajiggy (can't remember the name) so its not steel bearing or ceramic, and can withstand a lil bit more punishment than a standard turbo.
As a standard swap/upgrade for a R33 RB25DET i'd say get a 2530, but I dunno how they react to RB25DET Neo's.
Funky you have been talking about this setup for about 1 year now, when the hell will you get all these antilag thingamergiggies done?
SLY33
Is the 2835pro s going to fit on the stock manifold without modifications?
As for traction, good tyres and decent suspension setup helps alot!!!
SLY33
i hope so! i think it all bolts up. Kit comes with its own dump and all the lines. I think the one thing ill need is a new intake pipe as the compressor inlet mouth looks big, but im fairly sure its a blot on kit.
can someone with ~280rwkw comment on drivability? are these cars still fast at speeds below 100 or is it just wheelspin city?
While i love power, it makes you slower if you cant get it down!
Damn impressive resutls...are you sure it was only 13psi:confused: I have read of those sorts of power figures at 1.3bar. Is it a std RB25:
No its not standard. I dont know what has been done other than bigger cams, injectors, external wastegate, it was a import this is how it came. It was dynoed by Brad Sherriff in Tassie.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
