hey people new to the forums and for the first post i have nice indepth question for u all and wen i asked my mate he told me to join these forums cause apparently u r a cluey bunch of people anyway
i am currently in the process of having a rb 30 rebuilt and am wondering if i can use a hks t51r turbo if this will be a big problem with it being to large of a turbo
cheers guys and if i missed anything leigh (dnb) please add wat else we need to know
thanks josh
https://www.sau.com.au/forums/topic/55278-hks-t51r-on-a-rb-30/
shouldent be a problem at all, hks t51 comes in a few differant models so suiting one for an rb 30 should be easy. first you should decide what you want from your engine and select a model you need. hks t51 come in 2 modles the t51kai and t51spl. kai is good for 800ps and spl for 1000+. prices vary depending which model you choose. there are also the usual ball bearing and non-ball bearing choice. other than that all you need is a manifold/ headers and to up grade every thing else.(fuel system, ecu, modify intercooler plumbing, oil pump rods and pistons.) it would be wise to spend a few bucks as doing it on the cheap could lead to a lot of problems. you would need a fairly strong engine as that turbo/rb30 combo could generate a lot of power.
Too big for what ???
One must qualify one's thoughts :D
In other words- what are you going to be using the car for ??
Tells us as a percentage ?
% Street
% Drag
% Circuit
% Drift
% Dyno Queen (no offence)
  • 5 years later...
Guest
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
