After installation of the deck there was no lights inside the car, no room lights or those reading lights?? any possible wire i could of connected wrong or cut which wasnt ment to be cut? colors or any details would be a great help peeps!
Unfortunatly i didnt no about this site when installing so couldnt follow the guide :D
Very common problem for home stereo installs. People get the dimmer wire mixed up with the Earth..... When the parkers are off its an earth, when they get switched on - its alive, and will throw the fuse.
There are 3 fuse panels in the R33, when I blew mine Im sure I replaced one in the boot.
Cheers
Sumo
Sumo, if this was the case when i put the parkers on wouldnt the deck turn off and throw the fuse? ive checked boot fuses, checked the fuses in the cabin, none blown? do i need to re wire it? any ideas as to what colour wire i have done wrong?
did you use a multimeter to identify the wires?
If not, now would be a good time.
First things first you have to find the bad fuse, one must be gone somewhere, sometimes it is hard to see, swap them with your spares on by one with the deck off.
Thats another good point SKYL9, that rheostat might have a wire off it.
BlackR33, Yes, first time it goes to blow a fuse, it will turn off for a couple of seconds - once blown it will not go out.
Use a test light for fuses, And yes, I did the same thing when I first did my stereo. I had no interior light/dash light/cigarette light
Cheers
Sumo
nah . you have killed 3 fuses. there is one in the back for tail lights the interior light one is in the panel above your right foot.
if you go out and buy an adapting plug for $20 it will save you the headache of the above and also another $80 or so that strathfield or the like will charge you to fix it. ( I charge $85 to fit one..)
this is really doin my head in, because ive checked every fuse in the car, when i got this problem i got a test light and tested every single fuse, first thing i did.
depends on who complied it. most of the ones I work on have a seriously botched item literally thrown in. if its the factory item then you have killed a fuse. those things arent that easy to kill..
Mate, have your stereo pulled out and go see an auto elec, they should not need more the 10 minutes to tell you whats wrong..... Just explain the symtoms, and they should be able to sort things out. It is a common problem with people that install their own stereos. I have seen a few blown up stereos from incorrect installation - just because people think they can save a few dollars by doing it themselves.
Cheers
Sumo
I've installed countless stereos - and I don't consider myself any sort of installer but I've never blown anything up.
How does this sort of stuff happen? Is it something I'm not thinking of or isit the most obvious stuff like shorting wires while they're being cut and stuff like that?
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
