After installation of the deck there was no lights inside the car, no room lights or those reading lights?? any possible wire i could of connected wrong or cut which wasnt ment to be cut? colors or any details would be a great help peeps!
Unfortunatly i didnt no about this site when installing so couldnt follow the guide :D
Very common problem for home stereo installs. People get the dimmer wire mixed up with the Earth..... When the parkers are off its an earth, when they get switched on - its alive, and will throw the fuse.
There are 3 fuse panels in the R33, when I blew mine Im sure I replaced one in the boot.
Cheers
Sumo
Sumo, if this was the case when i put the parkers on wouldnt the deck turn off and throw the fuse? ive checked boot fuses, checked the fuses in the cabin, none blown? do i need to re wire it? any ideas as to what colour wire i have done wrong?
did you use a multimeter to identify the wires?
If not, now would be a good time.
First things first you have to find the bad fuse, one must be gone somewhere, sometimes it is hard to see, swap them with your spares on by one with the deck off.
Thats another good point SKYL9, that rheostat might have a wire off it.
BlackR33, Yes, first time it goes to blow a fuse, it will turn off for a couple of seconds - once blown it will not go out.
Use a test light for fuses, And yes, I did the same thing when I first did my stereo. I had no interior light/dash light/cigarette light
Cheers
Sumo
nah . you have killed 3 fuses. there is one in the back for tail lights the interior light one is in the panel above your right foot.
if you go out and buy an adapting plug for $20 it will save you the headache of the above and also another $80 or so that strathfield or the like will charge you to fix it. ( I charge $85 to fit one..)
this is really doin my head in, because ive checked every fuse in the car, when i got this problem i got a test light and tested every single fuse, first thing i did.
depends on who complied it. most of the ones I work on have a seriously botched item literally thrown in. if its the factory item then you have killed a fuse. those things arent that easy to kill..
Mate, have your stereo pulled out and go see an auto elec, they should not need more the 10 minutes to tell you whats wrong..... Just explain the symtoms, and they should be able to sort things out. It is a common problem with people that install their own stereos. I have seen a few blown up stereos from incorrect installation - just because people think they can save a few dollars by doing it themselves.
Cheers
Sumo
I've installed countless stereos - and I don't consider myself any sort of installer but I've never blown anything up.
How does this sort of stuff happen? Is it something I'm not thinking of or isit the most obvious stuff like shorting wires while they're being cut and stuff like that?
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
