  • Replies 237
r31nismoid. you dont have to pump the clutch to get it to break traction, your coming to perth, you can have a drive.
tristan
nice :)
ill say by looking at that no clutch required!
What makes it so savage though?
The dyno graph shows 438.7 rwhp at 162 kph, that's around 5,800 rpm in 4th assuming standard gearing and tyre diameter.
No air filter I notice, or ducting for it. I don't think I would be driving that around the sand blown streets of Perth, or the soot laden streets of Sydney/Melbourne either.
Can someone please tell me how I can get more then 310rwhp out of my stock injectors with the fuel pressure at 50psi ???
Not me, 310 rwhp = 231 rwk, best I can get is 225 rwkw.:)
Yes well 230rwkw is the most i can get with these injectors... They said that my fuel flow was good but pressure drops.. said i might have to hook my fuel pump up to constant power with relay.. does that mean anything to you Sydkid ??
It did make 240rwkw but it was knocking too much.. need to fix the fuel issue before i go chasing more power.
Yep, makes sense, the standard wiring is too small and can't handle the current that a large fuel pumps draws. I use the standard wiring to switch the relay and supply it with solid power straight from the battery. I use a 30 amp fuse at the battery to protect from busted wiring, that's what an 044 needs anyway.
Be careful with the standard fuel hoses, clamps and pipes as they are not designed for 50 psi.
The thing that confuses me is how you get so much power out of such a turbo.
I had the same turbo as magic1 (Gt30 .82 rear), Stock head, stock injectors (hi flowed to make 420rwhp) and this was my power curve.
The 1st pic is the re-tune with new engine. 2nd pic is of the old engine with the tune. As you can see we had to run such hi boost to achieve that power level. I dont know why but i believe it may to with the turbo and stock cams.
Then i see the figures steve sst makes with stock head or less boost.
My dyno was not in shoot out mode not sure if it will make a big difference how ever.
Could some one explain why or how steve sst can make so much power from these turbos??
I dont think it could be the difference in the computer (i used microtech).
My whinge.
I guess it comes back to the turbo - I'm getting 330rwkw at 21PSI - Boost drops from 25 PSI (at 4000rpm) to 21 PSI. (at 6000 RPM) If I run 21 PSI base boost, I get same power - no boost drop.
What my thinking was, that if I increase boost to the 25 PSI, I will see more power - but there must be some other restriciton - can could be Exhaust, W/G, Turbo, etc.
Am running trust Type R Ex. W/G (45mm, 18 PSI spring pressure) and Turbosmart E-Boost - that's a pretty good combo.
Have you tried dropping the exhaust? That will tell you if that's the problem. The next test is boost before and after the intercooler. If the there is a restriction there it will cause the symptoms you have described. You may also need to measure the restriction in the turbine, it may be getting so high that it matches the boost coming in. And then there is the airfilter question.:)
Have you tried dropping the exhaust?  That will tell you if that's the problem.  The next test is boost before and after the intercooler.   If the there is a restriction there it will cause the symptoms you have described.  You may also need to measure the restriction in the turbine, it may be getting so high that it matches the boost coming in.  And then there is the airfilter question.:D
Also,
Do you have a blow off valve that could be leaking boost ??
Ok.... I was scrolling though the forum as usual and I found this post by Magic1 a while ago.
That thing that really caught my eye was the "Bigger then factory" are they really running stock injectors? So the question remains....
magic1
Registered User
Car(s): R33 GTST
Trader Rating: (0)
Bigger RB25det injectors
Looking for 6 clean RB25DET injectors, bigger than factory. Anyone got any? Please PM me.
Regards
Tristan
__________________
511rwhp - Much more than GTS-t VSPEC
Just trying to keep it between the ditches
http://dynamic-www.skylinesaustralia.com/f...=rb25+injectors
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
