R33 GTS 511rwhp-Stock injectors DYNO
magic1
 Share
  • Replies 237
Sorry Sydneykid for the late reply, as you asked i have been gathering infomation to back up my claim. From what i understand you work for a race car team, use motec in your race cars and are very knowlagable in you area. I am prepared for your critcism and happy to reply, as you keep the thread positive. unlike like the other dicks here.
The wolf is a better computer because
1. Price, compared to the motec of simliair features the motec would cost over $7000
2. Idle speed control
3. it is a true plug and play
4. from exprience the fuel delivery
5. does not need CDI modules to run the coils properly.
6. the wolf has 2048map points, motec 1048
RNS11Z, i do have cams in the head, 256 in 264 ex, i will confirm mph on wednesday.
TIMMMAYYY, (acutual Pimp) give me a break you ****ing retard, i will answer your questions when you are polite enough to answer mine.
ronin6 your opinion is well founded, the wolf has very basic data logging, an apsolute must for racing.
rev210 :D
raist60, smoke the coils, i will keep reading, ???????? no idea im not running at over 90% duty cycle.
dnb i would love to , my car is open for inspection, changing injectors not easy, lots to remove.
IMACUL8, i will talk it up, do you have a motec?, if so talk it up. clown
INASNT yes im a wolf salesman, lol. did that take you long to think up.
R32-GTS :D
INASNT another quality installment, do you think before or after you dribble.
BU5TER calling my self not the best drag racer would be to oposite of arrogant.?
RB20LagWagon cry cry cry, yet again.
my car is for real, sydneykid hope this is enough.
tristan
And what do we all expect to happen when he does, he's never been to the drags before ... hell it took me 6 months to get times that were 1/2 respectable out of a 400+hp car, it is not easy at all in a RWD how about we pressure him less and let him enjoy his car and after a few months of racing we have a look at his mph and judge it then :D
I for one don't want to see a nice skyline end up in the wall
there has been way to much pressure placed on tristan
none of this is his fault
his car makes that power full stop. it hasnt done a time full stop. he wont drive it to a time full stop. those are facts, **** the excuses and the arguing, what happens happens.
its a shame tristan is being used as a pawn by others to create arguments or to show off about how good their products are.
Good luck racing it, mate. Post your progress. I will suggest that the mph will be a better indicator of the cars' hp and potential ET's for the first while until you get a handle on the beast.
Adrian
A close friend of mine is one of the directors(owner) of AEM (advanced engine management) the manufacturer of WOLF ecu's.....I will have to commend him on his work next time i see him :)
Maybe he can hook magic1 up with a part time job :)
Magic good luck at the strip, what tyres and suspension setup will you be running?
Now I definitely think you aint running 370cc injectors dude. Wow! Less than 90% duty cycle on a 370cc injector (which makes 333cc best case) with 300+ rwkws.
CAWWWW!!!!
 Share
    • Hi all,   I have bought a JDM R35 at auction in Japan.  This is my second JDM GTR after owning one back in 2009.  I have made a couple of videos that may interest some forum members.  One is collecting the GTR from the compliance shop (and seeing it for the first time) and another on the process of buying and importing a car from Japan.  I'm new to this and would appreciate your thoughts, as well as a subscribe!
    • Sorry, AFM.    Will edit original post
    • Oh, yeah, no arguing that the duty cycle is different. And a circuit car will go to those speeds for more distance and longer times. But, I suspect that if a tailshaft has a harmonic problem, that it would cause damage and shit itself maybe even on the first pass. A second or two of running at the resonant/harmonic problem speed is already a couple hundred revolutions.
    • Shaft speed would be the same, however it's how long they hold it there for and repeated conditions. FWIW half way down the main straight at SMSP I'm bouncing off 4th with a 8600RPM limiter. That shaft would be spinning at 8600RPM for a few seconds before I need to smash the brakes, by T2 it's getting close to that speed again. Now a drag car/roll race car would see that shaft speed for a 1 to 2 secs then they would coast, hit the brakes and that's it.
    • With same diff ratio, tyre diameter and road speed, the tailshaft rpm is the same regardless of the gearbag's ratio. Given that very quick drag cars are probably doing similar road speeds to the fastest circuit cars (circa 300 km/h), and there will be many of either category that can't go that fast and so you'd have inummerable matchups between drag and circuit car speeds at smaller numbers, and given that they are probably using rather similar tyre diameters and probably using similar diff ratios, and...where any of those numbers were different they could quite easily be in opposite directions thus cancelling out.... I think you'd find that there'd be more similarity than difference in tailshaft speed between these two use cases, no?
