Q) I have BA Falcon and I don't like the stereo
A) Read below
My friend got his xr6turbo mark II yesterday and we went to garys car radio to check out stereo options for it.
Headunit and Engine Management System
The BA falcon head unit is part of the engine management system and if removed/disabled it will cease to function and render the car un-startable. The headunit system is about $2000 brand new if its busted or damaged. They can also be repaired for a small fee to a few select electronic freaks if the damage isn't too bad. There have been some cases of the unit being damaged by tampering and you have one of those two options, costly either way.
Premium Sound vs Standard
The head unit I am talking about is the sound upgrade option. Not to be
confused with the Premium Sound option which has the TV display. The upgrade sound option has a 6 disc built in stack and its the stereo control and aircon control in one.
3rd Party Headunits
If you want to install your own head unit it must be installed in another location, the first place would be where the cigarette and tissue compartment is. We had a look at a BA falcon today that had this setup. The only downside to this is the factory head unit is still there and still works, just no sound comes out of it. You can then tap your head unit into power, acc, ground and speaker wires according and the other downside is the head unit is down low and just in front of the gearstick
New speakers & Amps
If you opt to keep the factory unit which you can do then you can get the front speaker wires, install a stinger high gain adapter and use it as a form of RCA out. The stock headunit doesn't have RCA preamped/gain outputs so you have to use inline adapters. You can then run these to your own amps and replace the factory speakers with 6" splits and and subs and amp to your hearts content. We got an install that used the front wires with an inline adapter and this ran the fronts and rears on a 4 channel amp. The rear speaker wires from the stock head unit were plugged to a monoblock amp and the set off to run 2 x 10" subs.
Caution
We were cautioned about doing this setup in the event of spark or voltage surge the factory head unit could be damaged or placed at risk and then be up for some costly repairs. The solution was to use inline fuses on the speaker wire so they break before the voltage/surge gets to the head unit. Although not 100% a lot better.
Result
This was the most cost effective and easiest method whilst retaining the factory system as it has controls on the steering wheel to choose tracks etc.
The standard system is a 6 disc in dash changer so its not too bad as a full package.
Conclusion
It seems Ford wanted to prevent people from changing the head unit and tampering with its sound setup. If you want better sound and a better setup they wanted you to get the premium sound option.
https://www.sau.com.au/forums/topic/55334-faq-ba-falcon-and-stereo-changes/
fun stuff!
As an aside Nissan tried to do some similar stuff with the R34 GTR and the built in LCD display has no RCA input or any easy way to plug your own video source into it unless you option it when you buy the car. They had at least 10 different Navi/TV options you could choose from the factory and/or dealer.
Luckily nowdays there is a guide floating around on how to hook any NTSC video source up with a bit of soldering and I have done it on mine, installed a DVD headunit, and watched "The Usual Suspects" on the screen the other night. Works brilliant :P:)
fun car to work on. (BA) did one today with TV interface and a decent stereo as well.
this one had the premium system on it and I still have a bit of a probelm with engine noise on it . this is using the stinger line out units.
if you are playing with the unit ( IE pulling it out) have the keys handy.
still waiting for someone to throw a 34 GTR at me...
still waiting for an alternative mounting from aeropro. was talking to the local rep and he's says if theres enough interest then they will make one...
( I already get 5-6 called a week on VY commys.. same problem easier solution.)
    • I know mentally you're set on the ATS clutch but honestly I'm a big fan of the Nismo Super Coppermix Twin. It's much cheaper and in some ways I think it's a better design for a street/circuit car.
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
