hey guys...
how much would this conversion cost ( rb20 in a 180 )  say from a r32 f/c or a cefiro f/c & i'de be selling the sr20det + gearbox...
any are there any issues with this conversion ??? thank you!!
A 5 speed manual RB20DET 1/2 cut with the front brakes sells for $2400. You should be able to sell your motor + g/box + loom + ecu + afm etc for around the $2000 mark.
The motor physically bolts in, you use the R32 radiator, crossmember, g/box mount, power steer pump. While you are upgrading the motor, I would suggest doing the 4 pot caliper upgrade to the front.
You can't use the engine fan as there isn't enough room between the fire wall and radiator support, so thermo fans are used.
maybe seeming you will get some decent $$ for the SR20DET, get yourself a rb25det...
but going from sr20det to rb20det, same as above... why?
I am currently doing the conversion myself.. from sr20DE to rb20det any questions... let me know
Not an rb20 please. Get something decent like an rb25. Or better yet dont do a conversion. The sr's are well known for their ability to double their power with bolt on mods. with over 2 grand you could get a few parts that would go on that would make decent hp, like a frount mount and a new turbo, possibly injectors though you would be streching your budget.
the issue..
why the hell would you swap out an SR20 with an RB20?
the SR20 kills the RB20 hands down, and your 180 will be waaaay to front heavy with an RB20 anyhow.
I'd stick with an SR20 all the way
I have a RB20 in my S13 hatch... great motor and the car has excellent handling with my Kei Office Type XT footwork... don't mind what people say about the RB making the car front heavy. Check my signature to see the details on my car.
Granted... if I had a SR in my car originally... vs my original KA24DE truck motor... I'd just sell my S13 buy a used GTR.
    • I always find it both fascinating and educating seeing you go through all this. It's a bit like "BMWs are great. Except with one massive caveat: as long as you fix this two page long list of things where components are broken by design" Every now and then I consider getting a BMW. And then I read your posts and think that maybe the RB life is not so bad after all
    • For the record, I hate the colour. Even if I'll never see it again, I know its in there.
    • This is another issue I'm fixing. This little valve stops all the oil from draining to the sump when the engine is turned off. What happens eventually is that the engine is a little noisy and has the oil pressure light on for a few seconds after turning it on. Basically it takes a few seconds to build the pressure when all the oil has drained. This valve is a non serviceable part and is attached to the oil filter housing, BMW suggests to replace the entire housing if this valve fails.  As it turns out this valve can be removed and that means you can get an aftermarket replacement, which I did. The failure, for me at least is that the valve doesn't seat properly after a while, which I've demonstrated. The new one is a ball end and always seats properly.
    • Welp don't know if this is good but I can hear a sizzling sound in my battery Hope I didn't fry it. Turns out a bad battery in the multi meter will give a false reading (likely what happened when I said I had 15x volts), swapped the battery and monitoring now. I'm hoping that sizzling sound is just the equlisation charging
    • Yeah I'm happy to talk to whoever, I don't want to take ownership or even manage it if they don't want but I can probably help with hosting on the sau setup. It's a great resource and should be protected.
