I myself would not take the mesh out of you AFM, I could not see there would be that much more air flow from doing so, all I could see happening one day your pod falls of and a big bit of debris going into your turbo (Cringe) the cons out way the benifits. When I cleaned mine I use some electronics cleaner from JayCar the fine mist cleaned it a treat. dont worry about the cleaner going through your inlets as you do it with the engine turned off and electronic cleaner avaperates on contact, you should see the oil and crap that gets sucked in from the breathers that would get you worried...
  • Replies 110
Guest Pickled Icecream
Whilst brake cleaner and other products may not have a
detrimental effect to the performance of your AFM, why not use
electrical contact cleaner - a product that has been specifically
designed and formulated for cleaning electronic components, like
those in you AFM.
At the end of the day, its personal preference. Personally, I'll use
the stuff the boffins use.
Your Skyline would not exist without boffins.
bah.... i say pull them off and see if it makes a difference... that is if you can put them back on again!! lol
i don't see the point of having the mesh cos the air filter should have stopped anything getting through. If your air filter "falls off" or stops filtering then you obviously haven't done a proper maintenance routine and checked that there are no tears in the filter and that it doesn't need replacing or tightening.
Andrew
the mesh is there to stop knuckle heads from poking screwdrivers into the hot wire. It is a restriction and you will increase airflow/hp by removing it.
It is not designed to 'smooth airflow' it is just cheap-ass(uneven and poorly constructed) mesh.
Do yourself a favour after checking your head for knuckles.
I have found that electrical contact cleaner can be wanting, especially if whatever you are cleaning is really dirty. It is not uncommon for people in the trade to use other than electrical contact cleaner - I have a good friend who does work in the trade, and he uses all sorts of things - including brake cleaner for components that have come in to contact with oil/grease. He also uses erasors for cleaning electrical plugs, as he recons these work best of all.
I am not the only person that uses brake cleaner for AFMs, and I would challenge you to find anybody who has ever damaged their AFM by using it. I am not saying that brake cleaner is your only option, just that it is a viable option that provides good results very quickly and easily - which is the point of the forum. Also I am not saying that electrical contact cleaner is no good, just that there are other options as well - and to each their own.
As for common sense - well I strongly believe that there is no such thing...lol
Steve-
With there being multiple ways to skin your neighbourhood cat,
there are also multiple ways to clean your AFM.
Never did I mention that using anything besides Electrical Contact
Cleaner would damage an AFM. I was simply suggesting to the
more timid and hestitant Skyline owner, that ECC would be a very
sensible choice.
A sensitive output device like an AFM is heavily reliant on its
accuracy, which is why I, personally, would opt for the gentle
decontaminating action of ECC.
This is just my opinion, and I respectfully accept yours.
In this instance, neither of us are incorrect.
As for common sense - well I strongly believe in attaching your
bungee cord before you jump.
Hi guys, I use only products that don't leave a residue, so WD40,
RP7 and Carby Cleaner are out. Non residue stuff like EEC or Brake Clean are the go. I have even used straight metho (pinched it off a guy in the Cross one night) when the car wouldn't start.
Hope that helps.
Ooops, almost forgot about the "removing the mesh for increased power" posts. If the restriction of the mesh is the limiting factor in the power chase, then removing it will give a result. But only if all of the other bits, like airfilter, inlet pipework, turbo, camshaft, head, rpm, intercooler etc are being held back by the mesh's airflow restriction. Pretty unlikely in most cases.
Hope that adds to the discussion.
Steve -
No problem. It is quite easy to be misunderstood under
these circumstances.
In relation to the removal of AFM mesh. I recently removed mine
for a number of reasons.
1. Zoom said so. (I also eat Special K to make me look good in
tight jeans and torn red shirts that accentuate my breasts, and
drink CC and coke to make my skull indestructible)
2. I was bored.
3. I can understand how removing the mesh could possibly,
maybe, one day, if you're luck, prove to be beneficial.
4. I performed a stupidly simple test that, through my powers of
super geniusness perception, I already knew the
answer to. Much like knowing that inserting your penis into a
toaster whilst making your morning meal may cause erection
defects.
Test - Once having removed AFM, use your mouth to blow
through the meshed AFM with your hand on the other side, so
you can feel the goodness. Then, keeping the distance from your
mouth to your "sensor" hand constant, remove the AFM from the
equation and blow directly onto your hand with identical force.
In that particular instance, the meshed AFM caused a restriction.
BUT...
When I think of the velocity and quantity of the exhaust gases
that those six pistons are pushing out through the exhaust
turbine to spin that shaft - It reminds me of my foot, and an ant.
In short - I am sceptical, but what the hell! It kept me away from
pornography for 20 minutes and reduced the Skyline's total mass
by 10 grams.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
