  • Replies 110
Mate has taken out the mesh on both sides of his Z32 sensor & actually dynoed it! And guess what it made more power with the mesh removed, plus he actually flow bench tested with & without the mesh & picked up a bit from removing it! he actually went a step further & got some epoxy ribbon & made the plastic section where the wire is inside smoother & also flowbenched this which again improved flow & hp on the dyno! This car has really good A/F ratios now without a modified ecu other than the speed limit removed & made approx 209rwkw ( not on shootout mode either !)& ran 12.592@182kph! This is not BS you can check the time on http://www.drivelinechatter.com/dragladder_list.asp to verify! obviously it has other mods but mods to sensor seemed to help his a/f ratios
sends mixed messages to the ecu
i doubt removing both of the grills would send mixed messages. there is only one input - the AFM - to tell how much air enters the engine. this is measured after the first grill - and only measures how much air hits it to cool the wire
Originally posted by rev210
from the look of the mesh there may be as much as 3-4kw@motor in the top end by removing both. More if you have a higher output engine than stock (ie: big turbo)
What is all the talk about *both* or *two* pieces of mesh?
Mine only had *one* on the airbox side, which is gone now...
Maybe its just one of the differences in the models ~ 33 > 34?
the mesh is there to stop knuckle heads from poking screwdrivers into the hot wire. It is a restriction and you will increase airflow/hp by removing it.
It is not designed to 'smooth airflow' it is just cheap-ass(uneven and poorly constructed) mesh.
Do yourself a favour after checking your head for knuckles.
That is a classic ~ very funny!
Hope I'm not interupting, but I was told 2day by BD4's that the k&n, unifilters and others along the same line use oil in the sponge and that it could damage the engine if the oil leaks.....they recommeded HKS air filters ....as it used steel mesh rather than sponging with oil.
Is this true?
Apologies for goin off the topic.
I would imagine that the oil from these "filters" is no worse [or better] than the crankcase return which goes through the turbo anyway...
unless of course you have an oil separator / catch tank.
hotino and others, although the link below has already posted in a different thread. It is a very interesting short read about some brands of air filters, their effectiveness, and how their manufacturer can promote misleading information.
http://www.mkiv.com/techarticles/filters_t...st/2/index.html
edit: It might shed some light on some misconceptions going around as to which type of filter is best for your car and your AFM.
Guest TTZ32
Definitely a worthwhile mod, from memory(been a while since I did it) removing the screens from the AFM increased the flow around 120CFM @ 10" water, it improved the flow by around 25%. I did it to improve spoolup more than anything, but it gave a gain in HP also.
It's all the little things that add up to a large gain, and the cheaper the better.
I don't think there is any advantage to an oil filter.
Hmm, well i cleaned my AFM.. made sweet f.a. difference so either it was clean or it didn't matter.
Found out that both screens on mine had already been removed... there was a tiny bit of dust lining in there, not that great, but probably just proves how crap most pod filters are at actually filtering air.
Guest TTZ32
The hot-wire element is actually self cleaning. After the engine is switched off, the ECU heats the element red hot for a second or so to burn off any crap.
But they still seem to get a build up of snot on them over time.
For interests sake, I've been cleaning mine occasionally over the last 4 years, using carb cleaner, no particular brand, and haven't had any problems. The first time i cleaned it, I used carb cleaner and a toothbrush to scrub it. The element is very robust and unlikely to be damaged easily.
I can't recall EVER hearing of a Nissan hot-wire falling apart.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
