Hi,
My spec2 97 model has this exact problem. Stalling frequently whren coming to a stop and idling really roughy. Like the rpm cycles from 1500 rpm down to like 100rpm then back up over and oever and eventually will either stall or stay at about 1000rpm
can anyone suggest what i should do to correct this?
what steps are involved? you suggested cleaning the airbox? please provide some steps, i dont know heaps about cars, only a little bit
  • Replies 110
Guest RedLineGTR
Just cleaned it a couple days ago, may of made a bit of difference but not that noticeable got a can of electrical contact cleaner, got a can for about $21 or so dollars, but beware some of the contact cleaners leave a sticky residue, had a little spray on my hand and it disappeared in a couple seconds. Went home pulled the bitch out and started spraying, spraying, spraying...oops used the whole bottle..lolz but at least i could see the color or the actual unit itself. Prop do it once in a while but wouldn't bother doing it like every oil change or something like that.
If people have idle problems as most have on these replies I would recommend some, thoe $21 is a bit of a waste of money but with some testing the engine seems to be finding the correct revs at idle & calculating air entering the system more accurately.
PS. IF you wanna use brake cleaner by all means do if it works fine, my experience with the contact cleaner was great no problems, Just choose the right one. (dicksmith guys that work there a dicks so when they have walked away, try some sprays out for yourself)
Cheers Rob
Guest TTZ32
Originally posted by paulr33
Hi,
Check the AFM is actually connected:) Maybe it's faulty, also check the coolant temp sensor and connector
Originally posted by RedLineGTR
....but beware some of the contact cleaners leave a sticky residue, had a little spray on my hand and it disappeared in a couple seconds...
Yeah, the one I said Rob, FLUX OFF leaves NO residue either! I cleaned out my mobile and got it working with this stuff ;)
My AFM doesn't seem to be dirty at all ~ yet!
Idle is a tiny bit uneven occasionally but I don't think its AFM related. Most likely due to CAS and idle adjuster being messed with...next dyno session will sort this out though...more than likely
Just for comparison sake, I got some brake cleaner, cost $9 and gave the AFM a quick squirt (a couple of seconds) and it was like new.
If you are having idle probs, it may be more than jsut the AFM, check all hoses that are connected to the plenum/intake pipework, make sure none of the clamps are loose, and check all hoses for damage. Ihad a small crack in a thin piece of rubber pipe where my boost guage was connected, as well as a couple of loose clamps. Sorted these and idle problems disappeared. Also you could try cleaning your AAC valve, as these sometimes cause problems.
it may be worth doing a search about idle, as a few people have had similar probs.
  • 2 months later...
Guest GTSFOUR
Cheers Rob
Well As A "DickSmith Dick" I find you Harsh generalisation offensive. But AS you are a fellow skyline fanatic i might just let it slide. Guys the best thing you can get is Electrolube Ultrasolve cleaning solvent for these reasons
1. It is exactly the job it is designed for
2. "contact cleaner" also lubricates as it is made for cleaning switches which can affect the way a AFM works
3. cheaper stuff will damage plastic if allowed to sit or used in great amounts
4. Its only $17 so why not
  • 3 months later...
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for ?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for  >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate modern almost all cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
    • Let's be wary though, if cranking is so far off, what else isn't set right? Are the dead times set right, voltage compensation etc?   It definitely sounds like it's cranking fuel issues, and holding flat to the floor is shutting them down, but I'm with Duncan that if nothing was changed in the ECU at all, and then this started, I'd be more thinking a leaking injector.   Do as Duncan said, drop the oil and make sure it's not full of fuel.
    • It actually means give it less throttle.
    • Yeah if the goal is to drive something then modifying a car is a bad idea.
    • Wowee! She looks like a major handful out there Pete!
