Hi,
My spec2 97 model has this exact problem. Stalling frequently whren coming to a stop and idling really roughy. Like the rpm cycles from 1500 rpm down to like 100rpm then back up over and oever and eventually will either stall or stay at about 1000rpm
can anyone suggest what i should do to correct this?
what steps are involved? you suggested cleaning the airbox? please provide some steps, i dont know heaps about cars, only a little bit
  • Replies 110
Guest RedLineGTR
Just cleaned it a couple days ago, may of made a bit of difference but not that noticeable got a can of electrical contact cleaner, got a can for about $21 or so dollars, but beware some of the contact cleaners leave a sticky residue, had a little spray on my hand and it disappeared in a couple seconds. Went home pulled the bitch out and started spraying, spraying, spraying...oops used the whole bottle..lolz but at least i could see the color or the actual unit itself. Prop do it once in a while but wouldn't bother doing it like every oil change or something like that.
If people have idle problems as most have on these replies I would recommend some, thoe $21 is a bit of a waste of money but with some testing the engine seems to be finding the correct revs at idle & calculating air entering the system more accurately.
PS. IF you wanna use brake cleaner by all means do if it works fine, my experience with the contact cleaner was great no problems, Just choose the right one. (dicksmith guys that work there a dicks so when they have walked away, try some sprays out for yourself)
Cheers Rob
Guest TTZ32
Originally posted by paulr33
Hi,
Check the AFM is actually connected:) Maybe it's faulty, also check the coolant temp sensor and connector
Originally posted by RedLineGTR
....but beware some of the contact cleaners leave a sticky residue, had a little spray on my hand and it disappeared in a couple seconds...
Yeah, the one I said Rob, FLUX OFF leaves NO residue either! I cleaned out my mobile and got it working with this stuff ;)
My AFM doesn't seem to be dirty at all ~ yet!
Idle is a tiny bit uneven occasionally but I don't think its AFM related. Most likely due to CAS and idle adjuster being messed with...next dyno session will sort this out though...more than likely
Just for comparison sake, I got some brake cleaner, cost $9 and gave the AFM a quick squirt (a couple of seconds) and it was like new.
If you are having idle probs, it may be more than jsut the AFM, check all hoses that are connected to the plenum/intake pipework, make sure none of the clamps are loose, and check all hoses for damage. Ihad a small crack in a thin piece of rubber pipe where my boost guage was connected, as well as a couple of loose clamps. Sorted these and idle problems disappeared. Also you could try cleaning your AAC valve, as these sometimes cause problems.
it may be worth doing a search about idle, as a few people have had similar probs.
  • 2 months later...
Guest GTSFOUR
Cheers Rob
Well As A "DickSmith Dick" I find you Harsh generalisation offensive. But AS you are a fellow skyline fanatic i might just let it slide. Guys the best thing you can get is Electrolube Ultrasolve cleaning solvent for these reasons
1. It is exactly the job it is designed for
2. "contact cleaner" also lubricates as it is made for cleaning switches which can affect the way a AFM works
3. cheaper stuff will damage plastic if allowed to sit or used in great amounts
4. Its only $17 so why not
  • 3 months later...
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
