Pics of Millenium Motorsports dyno day 6/11/04
my passage made 142.5rwkw and 330ftlb torque.
gotta get my intercooler piping done properly and not completely botched up by 1000 misc pipings and connectors :) waaay too restrictive for the t3/t4 turbo... i was hoping for the 160-170rwkw mark, but yeah :(
still does 13's :(
was a good day...came in a bit late but its all good,..saw some cars from SAU...the white GTR which im pretty sure from MELV..must say...AWESOME car,.would have stayed to see it go on the dyno but had to head back to sunny coast for work.
also saw MSP51 which i believe was Erins...my car was silver R33 GTST the one with the GT stripes on it.
Just bought the car not very long ago..wanted to see how much power it has and was quite happy..although i expected more he he.
done 156rwkw set on 8 psi
only known mods were 3in catback,.trust front mount and hks pod.--> seriously have no idea what other mods the car has..that's all i know---> FOR NOW.
and its time for an upgrade.
that's a good power figure for 8psi i think personally.
GTR man give carlos from millenium a call on 3348 2755 and tell him you saw it in the dyno day pics and wanted more information on it. I'm pretty sure he refills them and he has the setup on his supra so he would know the costs.
Some power figures for the day
Neil in his black rb20det 180sx 190rwkw
Stu in his white sr20det 180sx 192rwkw
josh in his white sr20det sil80 190rwkw
Mase in the povvo onevia rb20det 141rwkw with a fuel/air ratio of 10.2 rich rich
Melv in his white GTR 307rwkw
jaqule in his blue 33???
nismo 33 in his grey r33 156rwkw
chick in a Silver Supra 295rwkw
Red r33 built by hardcore performance rb25det 421rwkw's on the giggly juice
Chris sr20det green silvia 133rwkw's with air/fuel in low 10's
Scotty in champaigne 180sx sr20det 135 with similar air/fuel
Honda Accord with vtec engine upgrade 101fwkw's (almost put rwkw!!!)
Beannie in his r31 passage 142rwkw's (you just beat me you bastard!!!! :)) (air/fuel issues also)
Clint in his s15 pulled 163rwkw's
Overall the dyno day was great but showed quite a lot of us that we need to look at aftermarket fuel management if we want to see some decent gains due to some really rich air/fuel mixtures.
Few boys found out they were running very lean also, which may have saved them a lot of dosh down the track.
Silver Supra owned by a hot chicky with pink interior 295rwkw
mase how accurate is that dyno? u reckon??
i always was estimating my power to be anywhere from 160-180rwkw, and to pull only 142 i was disapointed.
yet people i've been speaking to have been saying that if im doing a 13.71 @104mph 1/4mile time, then i should be putting out about 180rwkw to even pull the weight of the passage along to that time. also worked out it was 142rwkw and 447nm torque... thats alot of torque for so little 'power' isnt it???
whats everyone elses thoughts?
beannie, your power figure was severely detremented by your fuel mixture. Maybe seeing as we cleaned your afm, the computer hadn't readjusted itself or something and you were running richer than normal????
If the dyno was reading low by around 20-30rwkw's then neil would have pulled a 220rwkw's. Is this possible on stock injectors???
With the boost you were running and your fuel mixture, i'd say that would be a good contribution to your lower power figure, but on the other hand, i do think the results may have been slightly lower (talking 10rwkw's max) than a few others around.
Just my thoughts anyway.
cheers for the pics guys
neil has pulled 220rwkw according to a post he made about the car...somewhere, ive seen it ... maybe not these forums, dunno... but yeah..
i might take it to a dyno dynamics dyno at a different place for a '2nd opinion' and see what i get... but honestly, i personally think its impossible for me to get a 13.71 pass on only 140rwkw in a car that weighs almost 1500kg :) we'll see...
Keeping in mind it is a dynologics dyno and not a dynonamics dyno.
They read differently. For instance, I got 198rwkw on matty spry's dyno and then went to all star tuning at northside somewhere and got 168rwkw.
So you figures were in comparison to everyone else on the day.
Twas me :) Just a question, what do those japanese characters on the back of you car mean?
Those Japanese writings means " Japanese women are hot " or rather " Asian chicks are hotter " --> something like that.
sweet hey ?
I don't actually have a 220rwkw dyno sheet, that's just an estimate based on past tunes at PITS and other people's power there. My boost was down 1.5psi from the last time i had it dynoed as well. However i have run 114.6mph which is well above what 191kw could run.
    • R32 pics Not sure if you can upload pics directly, but i've added them through an imgur link above.
    • There’s a possibility that Infinity G35x front hubs may be compatible, but it depends on the exact fitment. Sometimes, parts like hub and bearing assemblies from different models can work if the bolt patterns, bearing sizes, and axle specifications match, but the G35x hubs typically have a different design. It's worth checking detailed specs (like the number of bolt holes, size of the axle shaft, and bearing diameter) to compare, as Rock Auto does list some parts that cross over across different models. If you're going for a pre-pressed hub and bearing unit, that could be a good option. These units are usually easier to install, as the bearing and hub come pre-assembled, but you’ll still need to verify fitment, especially the outer diameter of the hub and bearing dimensions.
    • Love the input man! Defo gonna check it out
    • 1994 Series 3 R32 GTR. Freshly built as the perfect weekender. Has many brand new Nissan OEM pieces (some you can no longer source). Last serviced (April 2024) at V Spec Performance, Melbourne, Australia. Feel free to DM me if any questions. Asking price: $190,000 AUD.  Engine RB26DETT Original 05U block Factory R32 crankshaft CP 86.5mm forged pistons Spool forged rods Factory cylinder head – rebuilt Factory valve train Factory camshafts Factory inlet manifold Factory throttle body Garrett dash -5 turbos Custom intercooler piping with Plazmaman clamps Plazamaman 100mm race intercooler Turbosmart BOV Tomei fuel rail 660cc injectors Goodridge 9000 series fuel lines with crimped fittings Stainless steel front pipes Tomei titanium exhaust with stainless steel cat converter Spit fire coils Powder coated rocket covers New Nissan coil pack emblem badge Fully repainted engine bay in Factory Black Refurbished ABS unit New Nissan brake master cylinder New Nissan brake lines New Nissan clutch master cylinder New Nissan washer bottles Custom catch can (powder coated with Goodridge lines) Steering rack rebuilt New Nissan power steering lines New Nissan AC lines A/C compressor refurbished AC condenser refurbished HPI radiator and new thermos fanes New radiator fans NOTE: All nuts, bolts, fixings new or zinc coated Driveline Factory 5 speed gear box rebuilt Xtreme twin plate clutch Stainless steel clutch line Rebuilt factory transfer case Custom one-piece tail shaft Rebuilt factory front diff Rebuilt factory rear diff Suspension HICAS deleted Bilstein dampers IKEYA formular front and rear arms and tie rod ends New bushes wherever possible Whiteline anti roll bars (underneath car only) Brakes Brembo F50 front callipers – 4 piston AP racing 380*32 front rotors, J Hook design Custom floating hat and calliper mounts Brembo 4 piston rear callipers PFC pads Stainless steel braided brake lines Body New Factory Black paint job Ceramic coated exterior panels New Nissan aluminium bonnet (super rare) New Nissan headlights (super rare) New Nissan indicators New Nissan front bar New Nissan front lower lip New Nissan head light and bonnet seals New Nissan windscreen cowling New Nissan wiper arms and wiper blades New aftermarket windscreen New Nissan windscreen seal New Nissan front doors window surrounds and seals New Nissan rear quarter windows (must replace for proper paint job) New Nissan rear window surrounds and seals New Nissan side skirts New Nissan boot badges New Nismo rear bonnet lip New Nissan guard liners Interior New Nissan lens cover over cluster New Nissan gear boot shift New Nissan gear knob New Nismo steering wheel New Nismo floor mats New Billet Handbrake lever New Nissan OEM pocket facia to replace radio Underbody Original stone guard removed and new stone guard coating applied Powder coated front and rear cross members Fuel lines painted to match factory colours Fuel tank removed, cleaned, repainted and refitted All nuts and fixings cleaned, repaired and zinc plated Wheels Rays/Volk racing TE37 18 x 10.5 + 15 in Bronze Yokahama A050 265 x 35 x 18
