Do the Iron Mask cars all suffer from poor low beams ? I put +50 H4's in mine and the improvement was minimal . I should really remove the glass lenses to see if the reflector chrome plating is dirty or stuffed/corroded . Have any of you had this problem and found a fix ? Are new light units available ?
I've also refited the modified struts with the HDT Bilsteins and adjustable camber tops , anyone after some DR30 specific short Tokiko front inserts (suit lowered car) in Sydney ?
https://www.sau.com.au/forums/topic/55347-rsx-headlights/
No, not that I know of. I managed to find an alt with the same body, but had to swap over the cooling fan & pulley. I don't know what this alt was from.
If yours needs rebuilding I recommend Hampstead Auto Electrical on Muller Rd. They'll actually bother to get it re-wound if it needs it, whereas most places will just tell you it's knackered & buy a new one - even if it is only the diode pack.
https://www.sau.com.au/forums/topic/55347-rsx-headlights/#findComment-1096659
Im not sure of direct replacements,but if you can make a Bosch alt fit as they are cheap,common and reliable.
the alt may be aok,usually wiring/harness connectors are the cause of volt drop.A heavy wire(9mm) from the B+ terminal of the alt to the positive terminal of the battery is a good start.
https://www.sau.com.au/forums/topic/55347-rsx-headlights/#findComment-1096668
I drove my car the other sunday night for first time in over 18 months and i didn't have drama's with the lights, i've got a magna as a daily driver and i have to say that the lights were just as good as the magna...
As for alternators, apparently the drama's with the standard dr one's is, being internally regulated they can't keep up, yes there is a bosch alternator that does fit, Josh has swapped to one i don't know which one it is, but i know there is some wiring that has to be changed going to it but apart from that is a direct fit
https://www.sau.com.au/forums/topic/55347-rsx-headlights/#findComment-1099840
FJ alternators wasy . Aust spec Bluebirds (910 Ser 1,2) were fitted with Bosch alternators . Mine had the longer stator and rotor for 80a output . I also had the higher volt (14.7) integral regulator . Parts for these earlier alternators are getting thin on the ground , particularly the high output reg mine is an Ingrams , but they can be made to fit . The chief drama is the bulb check relay systems on Aust spec cars. The alt on mine refused to kick in and charge when started unless the engine got to 1300/1400rpm . Stay with the std Hitachi , better quality and reliability .
https://www.sau.com.au/forums/topic/55347-rsx-headlights/#findComment-1101344
    • Also, a tip for young players  Check the dates on new tyres before they fit them, I always ask this question at the tyre shop, as they have tried to put "new" tyres on one of my cars a few years ago, but the build date was about 3 years old
    • Yeah - 4 or 5 years is the limit for decent tyres. Pedestrian grade tyres with 400 TW ratings start out hard and don't start to suffer until they are somewhat older again. But the stickier decent stuff? Nup. My current ADO9s are < 2 yrs old, 17000km in, only have about the minimum 2mm of tread depth left, and they are.....not what they used to be. They are clearly much harder now than when new. Whether that is heat cycles (unlikely, for a road tyre), different compound between top and bottom of tread, or actually aging out (in less than 2 years!!!) is not really able to be discerned. But I'd credit actual aging as being at least part of the cause. I've got an old pair of ~50% worn AD08Rs in the shed that I really need to get rid of. They started feeling waaaay too hard to put back on the car after a couple of years sitting there.
    • Personally I wouldn't put tyres over 4 or 5 years old on any of my own cars. Once they go hard the grip characteristics completely change. As per most things it only matters in an accident and that's when you most want them to do their job!
    • I'm replacing the front tyres on the E39 tomorrow because one of them has a few gouges out of it. There is so much tread still on them but they're also 9 years old and the rubber is super hard.  This falls within the guidelines of 10 years old that I've read which surprises me given their condition.  I'm curious about whether you guys care about tyre age or just judge the tyre based on condition? How old would you consider too old?
    • What starts as a scratch, becomes a flesh wound, then quadruple amputation. Jus' sayin'. Crush resistant gloves (The ones with the rubber strips down the back of the hand and fingers) might not be a bad idea after all!
