  • Replies 199
Thanks for the support guys.
*spanks Duncan* cept for your ya wally :) nah jokes
I've been trying to get my hands on a trailer so I can whip around a track with it in the meantime. Trailer is low cost activity and the tyres aren't rego-able so I figure I might make some use of them :)
Anyone know if I can go on the track without rego ok?
yeah no rego and track = no problems, although the scruitineers may give you more greif. I think the EC/ARDC track days would require a log book if no rego but everyone else is OK.
Trailer = not so cheap, $2k up, or you can use ours for $50 :(http://www.skylinesaustralia.com/forums/sh...ghlight=trailer
Of course it is busy for most SAU events but if it some other time you should be OK
Hey Duncan that's sweet as!
I have a private track day I might be able to go to and I'm scared the gearbox will blow up - if it does I don't wanna be paying towing so if I have a trailor .. sweet.
I'll find out when it is and PM you.
haha fatz - now you know why I didn't make your track day :)
I was testing my half working jaycar IEBC today and lost 3rd gear also.
Lol locked out of 3rd and 4th. Funny stuff... So I took the clutch out, got angry and tried to shove it into 3rd and heard a clunk, then it went in :rofl:
But now they're both squishy lol
Hopefully get engineering, blue and pink slips in april along with a new box.
someonestolecc, may be the clutch, may not....
My R31 developed some masty selector problems and I started losing gears one by one - 5th, then 4th and 3rd - basically felt like it locked out of them, to begin with they felt kind of "non-positive" when you put them in, like they were stiff and you didn't really feel a click. Took a lot of effort to select and deselect gears. Also the lever wouldn't return past the neutral next to them, as in sideways- it would sit in the neutral between 1-2. I got it to loosen up and kept having issues with top jumping out, then that seemed to clear up....
Finally I reversed into a car park and it jammed into reverse/neutral space above it, and refused to go up/sideways to select the other gears. I had to drive about 3kms in reverse to get home....
It stayed like that for 2 months then one day I was sitting in the car cursing its capricious nature when I punched the lever and it loosened up, lol...
Now it works ok, but when its cold sounds like something is being spat around inside the box, like a loose chunk of something. Nasty.
Yeah that sounds about right actually!!
non-positive I call that squishy!! it started with 4th, now it's spread to 3rd but 3rd is intermittant squishyness.
Last night it wouldn't go sideways in neutral as I usually just wiggle it side ways when I get home as habit to feel if it's in neutral.
Also it gets stuck in gear but it's all intermittant - haven't had it jump out of gear yet but 4th can be easily taken out of gear without clutch (at any revs).
Mechanic said sounded hydraulic but he'll have to drive it to check - obviously over the phone ain't the same but I'll keep this thread posted incase anyone else got the same issues.
Cheers for the response - out of interest what do you think your problem is caused by ? And have you drained your oil and checked the plug to see if anything in there has shredded/let go? I don't wanna drop my oil just yet because I changed it in the last 1000km heh ... my car gets hardly any mileage now :
Thanks mate - I'm planning a celebratory cruise next month when my car is scheduled (ie when get my company bonus) to be engineered and rego'ed.. so you'll have to come along :)
If the bonus is big enough I might put in an organic/brass button clutch and get a new or recon gearbox but even without those things I'll be cruising as soon as it's legal (even if I don't have 3rd and 4th gear).
Brass button clutch = bad idea. You are not meant to slip the clutch with a BB, which means they are next to unstreetable IMHO and only really good on a track (be that racing or drag). Given you drive your car on the street -- and if I remember correctly, want to do a little bit of dori dori -- you want something you can slip.
LW.
That's exactly what I was thinking but I've never used a BB clutch.
I might search up what people are using for around 200rwkw + track abuse.
My mates 'organic' the local place put in for his r32 feels nice, the friction point/pickup feels like it's about 4-5mm without being too hardcore.
But what the hell is an organic? :)
I have BB clutches in both my cars. I reckon they aren't too bad for street. I haven't had a car with an organic clutch for probably 5 years though so maybe I'm just tough :P...
Organic generally means not brass or ceramic - The stuff that stock clutch plates are made from.
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
