Hi guys,
Does anyone have a custom boot install for an R33? I've got quite a few questions:
1) has anyone removed the spare and put the sub in there in fibre glass?
2) does anyone face the at the right side of the boot from the left side or vice versa and does this sound good?
How much does this cost?
post your piccies too
Cheers
https://www.sau.com.au/forums/topic/5537-question-custom-boot-install-for-r33/
I don't see a reason why you couldn't do something like this.
The question then is where are you going to hide the spare wheel?
I have a dual 12" sub setup in my boot. If you choose the right sub the boxes can be small enough that the setup fits comfortably between the strut towers leaving plenty of room in the boot for other things.
I had my sub box, a welder, a mid sized PC tower, heaps of metal, some PC speakers, keyboards and other stuff in my boot and still plenty of room left....
As bass is no directional I don't see a problem with having a sub on the side. As long as the box is made right then the setup should be good.
Dude I dunno about that... I have two 12's in my boot and theres NO ROOM left!.... Maybe an R33 has a much smaller boot then the cefiro? not sure
but anyway I was gonna buy one of those tyre puncture inflaters that mercedes uses for the SLK as the SLK doesn't have a spare either.
Originally posted by A31_Cefiro
IAs bass is no directional.....
I tend to disagree...
I can clearly hear the bass difference when the subs are upright and the front of the sub facing the front of the car, in comparison to having the subs right at the back of the boot, laying down.. Much better like that....
.. i think there's an ideal layout -- As far back as possible, flat down ?
By directional he means when you listen to bass notes, you can't exactly define where the sound is coming from (front, back, left or right). As opposed to higher frequencies (treble) you can clearly tell from what speaker the sound comes from.
A sub will generally sound loudest at the back of your boot (closer to the back seat) facing the back of the car. Called rear loading.
Guest Crazyfcuk
to shed a bit of light on the topic, ive taken the tyre out of my boot completly and now rely on a couple of cans of tyre weld and good tyres.
Um goto www.cardomain.com/id/crazyfcuk to see some of the pics of my install if you want cause i cant really be bothered explaining the whole thing again.
However if you've got any questions then just post them here and ill try to reply to them
Ive done more work to the car than whats on the site, but havent updated the stereo section yet will do in the next day or so. also theres some photos on at www.shoreracing.co.nz/nationalsphotos.htm its the one with the green rings around the subs and speakers. actually i think theres only a small photo, so ill post some more tonight onthe cardomain site
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
