I was just croozin today in me 230rwkw R33 and was thinking I am pretty happy with the way she is going at the moment... Even though you would expect a RB30DET to go harder.. its just a real pleassure to drive....
Thinking back a couple of years ago on what I was really wanting out of my car I dunno if i am really there yet as I need bigger injectors and better fuel pump before i can pump more then 10psi boost that im making 230kwkw outta...
So are you happy with your car?? what is on the WISH list for the mods you want.. and how much is that going to cost you ??
My wish List is..
1: Bigger Injectors
2: Bigger Fuel Pump
3: Apexi AVC-R or boost controll kit for PFC or Eboost.
Should make more power then....
Probly cost me about $3k...
https://www.sau.com.au/forums/topic/55384-are-you-happy-with-your-car/
For Christmas I would like the following:
T04E - $1000
800cc injectors - $400
Bigger NOS kit - $350
Haltech installed and Dyno - $1550
Slotted Rotors - $100 each
Splitfire Coil packs - $750
Adjustable cam gears - $300 pair
272 Degree Cams - $570
MORE FRIGGIN BOOST - $ABSOLUTELY FREE
oh and maybe a new paint job - $1100
my wish list is to have around 300rwkw or tad over...
so i hope santa has this in his sack;
hks 3037s turbo
greddy plenum
740cc injectors
fuel reg
hks 264 cams
adjustable cam gears
hks oil cooler
light flywheel
internals done
spray rocker covers
and finally some te37 with nitto's so i can attempt at seeing where my money has gone,
apart from that theres nothin else i wanna do...
ben...
A sticker pack from Autobarn with all the Brands on it.
A bad girls sticker.
A fully sick stereo.
Some crappy glitter paint.
No really
Powerfc
Steel turbines (Next week)
Dump pipes (When astro boy finishes them)
Custom Manifolds (ditto)
A new air regulator so it doesn't idle high.
Hmm... well ive wasted a lot of money on my car and it is SO close to how i want it. Only things i need:
1. Some Volks TE37s
2. My driveshaft to snap (so i can replace it with a CF one, if for no other reason than to say my car has one)
3. Someone to take the engine out of my car and give it a real good clean.
As for your $3k:
700cc Injectors: $750
Fuel Pump: $400
Boost Controller: $450
Tuning etc: $500,
So $3K would easily cover it
Wish List:
R31 silhouette or silhouette GTS, manual
then probably modify the RB30ET for even greater strength and reliability
fit RB25DET twin cam head (making motor RB30DET), I believe this is a simple modification because there is only one hole that needs drilling for the idler pulley, the boss for which is already in the top of the RB30 motor? if it isnt the RB25DET head that allows this can somone please tell me the head from which motor allows this?
Re- routed air intake, cover up original hole in front of airbox and run pipe out of a hole drilled in bottom of airbox to the air intake low in the grille and fit K&N filter, or fit pod filter
extractors and twin full exhaust
T06 Turbo and air- air intercooler
larger injectors
improved clutch and strenggthened gearbox
then probably a set of 18 or 19in mags
sticky rubber
full Clarion, Alpine or Pioneer stereo (I dont believe in hybrid audio systems wherever possible)
Momo wheel, gearknob and probably full Recaro interior
then drive and enjoy it until the bug bites again!
1. Some Volks TE37s
As for your $3k:
Fuel Pump: $400
Tuning etc: $500,
Where the hell can i get injectors for $750 eh ?? :P PM Me :)
my wish list...sum car...got p's but no car...wait the toyota vienta which i share with my dad, he says he'll get me a new car wen he has time....
hope that its a good car at least
here's my wishlist on wat to do with the car once i get it:
recaro bucket seats
steering wheel
alpine head unit
subwoofers
amp
4 speakers
and maybe a set of rims that i want
im not that technical with the names and stuff so ill leave it to the experts to deal with my new car :P hopefully i can get one by the end of dis yr
my wish list consists of -
the front of the car sitting at the same height instead of one side higher than the other
set of 18inch ROH fury rims
RB30DET conversion
t04e turbo
power fc
sard 550cc injectors
full coil over suspension
paint fixed up
new dash ( tacho doesn't work!!! )
GTR front bar and bonnet ( no grill cos it looks fully sik )
.... thats about it really - if i had about $10 - 12g's it would all be done.
WISH LIST:
1: 800cc injectors - $980 aprox
2: fix the key scratch some ****wit put in my car - $400
3: port & polish head, matching up with inlet/exhaust manifolds - $1000 aprox
4: tommi pon cams - $1000 aprox
5: apexi ax53b70 turbo kit - $2-2500 second hand
6: light weight flywheel + pully kit
7: arias forged pistons + rods to suit - $????
8: blueprint & balance motor - $????
9: pair of recaro seats - $800 each start price
10: customise whole interior - $????
12: Custom paint job - $7000 start point i think?
13: Do-luck 18" mags - $some rediculous amount (yes with nitto's)
14: might wanna stop, set of Ferrari F50 brembo brakes
i think that'd about do me.....by which time i should have bought porsche GT3 an been happy :whackit: ......nah....i'd have to mod that too :D
  • 2 years later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
