At the moment I know many ppl on this forum are jealous that they haven't been invited to a few of the DIY mechanics/bodyworks days. I am regretful to say that as of late a few of us have been conducting a few DIY days without letting everyone else enjoy the wealth of knowledge and quality worksmanship that myself and others have to offer. So in my lame attempt at redemption im going to let u know what you've all missed out on.
DIY Session 1: Bodykits and Bodyworks
The first thing you need is something that is broken or dented. In this case it was my front bar as well as joshes front bar.
First things first you cant go about this the way you think you should, you must conduct yourself in a true DIY manner. Sanding is always an option and in our quality work effort its not required, instead you should apply resin over the partly painted crack. Secondly (and its not neccessary to wait for the resin to dry) apply a modest amount of bog. For those of you who are lost and not as up to date. Bog is THE most essential tool for body work, if neccessary a whole section can be moulded from this extremely useful prodcut. Third, sand the bog back just enough to make it flat, you see if you sand it back to far you wont have enough protection against the next time you bottom out. 4th, go to the nearest super cheap and purchase whatever colour looks like your cars paint colour by matching the lid cover. (which is always the same colour as is in the can)
repeat the above process until your frontbar/sideskirts represent a retarded version of new.
DIY Session 2: Gaurd Rolling
Three cars where used for this excercise.
Some may pay money for gaurd rolling however this is well and truly uneccessary. When dealing with a car you have great respect for you should only ever trust yourself to do the right job. The tools you will require are a porta power extention and a sledge hammer. For the ppl who are extremely dodgy you can simply use the sledge hammer to "pump" out your gaurds. (pics to follow) These results were a little extreme and are not for everyone. The porta power extension however can be extremely affective. You place the extension between the gaurd and the wheel (note your car will have to be lowered for this excercise) now whilst applying pressure upwards onto the guard another person should proceed to drive forwards and backward until the desired amount of flare is recieved. Paint cracking is normal and DIY Session 1 can advise on how to fix this problem.
Lastly DIY Session 3: Clutch Replacement
Unfortunately you may need to outlay money for this experience and whilst this activity wasnt dodgy im sure you'll all be impressed with how recordly fast we were able to complete this activity.
Now for some you may belive that changing your clutch in a matter of hours is a great feat. However you people are simply fooling yourseves and you havent done the job properly. In fact the only way to ensure your job is thorough is to spend a full 2 days hard at it. Thats correct 2 days to install a clutch. Or more 1/2 hour to install the clutch and 1.8 days to install the gearbox. I know your all marveling at how extremely fast and experienced this may sound but one day you too may be able to achieve this, all it takes is practise.
Humerous photos of all the above are to follow...soon
I know your all jealous and wish to endure some of this quality work so put your names down below for the next day in just 2 weeks time.
(All the above stories are unfortunately true and names havent been changed or editted to protect the innocent.)
https://www.sau.com.au/forums/topic/55392-very-important/
The key word is filler, just dont use bog, put a couple of golf balls in there and fill the rest up with bog, or just find bits around the house which you dont want and fit in there, saving even more bog and making useless objects usefull again! :) :)
https://www.sau.com.au/forums/topic/55392-very-important/#findComment-1080607
I’ve been contemplating fixing this myself. Although Using that amount of bog, may just be too dodgy!  :)
josh im disapointed, done give me that soft attitude. I'll be round to the "workshop" this arvo, you know as well as I do that some cardboard and bog will fix that up god as new. BTW Take some pictures of your DIY boost controller and do a small tutorial for those who don't wish to waste unneccessary money on boost controll!! :)
https://www.sau.com.au/forums/topic/55392-very-important/#findComment-1080757
The key word is filler, just find bits around the house which you dont want and fit in there, saving even more bog and making useless objects usefull again! :D :D
I once bought a datto 1600 that i did a fair bit of body work on, and when i cut a previous(not me) bog attempt out i found loaf of bread used as fill in the sill!
https://www.sau.com.au/forums/topic/55392-very-important/#findComment-1080881
SKA show them the DIY Atmo bov (chinese take away container)
stay tuend for how to effectively tune your carby car without the use of an air filter...
Hint: all you need is a screw driver and a bundy rum can (preferably squashed flat)
https://www.sau.com.au/forums/topic/55392-very-important/#findComment-1081146
ok ok, because there is so much request for our expertise I'll release our much talked about DIY boost controll method.
DIY Session 4: Boost Controll
Many of you may have been fooled into buying bleed valves, in some cases even expensive electronic items. All i can do is frown at this behaviour. You have all you need to make your own at your local hardware store! What your going to need for this exercise is a piece of vacumm hose, prefferably long enough to reach from your actuator to near your pod or airbox and a screw (pictured below) and a screw driver (philips head)
After obtaining these items you need to decide one of two things. Just how much boost do you wish to run and whether or not you want to be able to adjust it.
OPTION 1) Run the vacumm hose off your actuator with no screw in the end. This method is very effective performance wise, however it MAY lead to destuction of things such as your turbo. Not to worry fuel cut will save you. This method shows how truly hardened you are and indicates just how much boost your stock turbo can handle before literally throwing chunks of the exhaust wheel out your exhaust. Some may view this method as a little extreme even though it has proven promising on certain cars :D. Not to worry option 2 is for these people.
OPTION 2) This option is for the light hearted. You take your vaccum hose and bring it all the way to near the pod. You then use your screw and screwdriver to implant the screw in the hose. (seen below) The further you screw it in the less boost you will run. To get maximum performance we suggest road tuning, to optimise the boost level.
These are unfortunately the only photos we have atm, however there will be much more soon! Including pictures from previous DIY sessions.
until next time....
https://www.sau.com.au/forums/topic/55392-very-important/#findComment-1081182
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
