nizmokid Posted November 7, 2004 Share Posted November 7, 2004 what is the in's and outs on these? and do they fix the coilpack problems (4000-5000 popping) people get from there skylines??? Link to comment https://www.sau.com.au/forums/topic/55404-splitfire-coil-packs/ Share on other sites More sharing options...
thizzle Posted November 8, 2004 Share Posted November 8, 2004 i just got some few months back highly recommend them...cost me 1000$ and stopped the problem dead never missfire again....my mate did the same we both have r33 gts-t now we hit 7000 all day wihtout a pop Link to comment https://www.sau.com.au/forums/topic/55404-splitfire-coil-packs/#findComment-1080692 Share on other sites More sharing options...
croat Posted November 8, 2004 Share Posted November 8, 2004 Yeah they do. best thing i bough engine wise so far. improvements all over the rev range! Link to comment https://www.sau.com.au/forums/topic/55404-splitfire-coil-packs/#findComment-1080863 Share on other sites More sharing options...
bangahh Posted November 8, 2004 Share Posted November 8, 2004 what is the in's and outs on these? and do they fix the coilpack problems (4000-5000 popping) people get from there skylines??? theres a thread by someone that the is a hairline crack on the coil, if you tape that up it will stop the 5000 poping / boost cutting feeling. also in that thread, someone argued that the power fc or was it a safc will resolve that problem too. dont know if its true or not, so i will have a look at the coils this weekend and tape it, cause mine pops alot and cant keep up with the boys Link to comment https://www.sau.com.au/forums/topic/55404-splitfire-coil-packs/#findComment-1080896 Share on other sites More sharing options...
RBVS Posted November 8, 2004 Share Posted November 8, 2004 i was looking at pricing an alot of place's are like $1000 then checked nengun and they are $580 deliverd... wow there killing it. Link to comment https://www.sau.com.au/forums/topic/55404-splitfire-coil-packs/#findComment-1081153 Share on other sites More sharing options...
Duncan Posted November 9, 2004 Share Posted November 9, 2004 were the $1000 prices in Aus for immediately available? Because the Nengun price may require 15% duty + 10% GST making it $750, and could take a couple of weeks sea freight. I guess people are often willing to pay more to get them sooner Link to comment https://www.sau.com.au/forums/topic/55404-splitfire-coil-packs/#findComment-1081864 Share on other sites More sharing options...
Robo's Posted November 9, 2004 Share Posted November 9, 2004 Sounds like the stock coils are pretty weak. Link to comment https://www.sau.com.au/forums/topic/55404-splitfire-coil-packs/#findComment-1081941 Share on other sites More sharing options...
Gav Posted November 9, 2004 Share Posted November 9, 2004 Sounds like the stock coils are pretty weak. Nope - just many years old and been through lots of heat cycles (ambient to maybe 80C). Given these conditions, I think that they survive pretty well! After messing around with buying used coils, I went for the Splitfires to get rid of the missing once and for all. New coils from Nissan are actually more than the Splitfires. Link to comment https://www.sau.com.au/forums/topic/55404-splitfire-coil-packs/#findComment-1082029 Share on other sites More sharing options...
cav Posted November 10, 2004 Share Posted November 10, 2004 what boost are you guys running my car is popping at 10 psi, will the coils fix it or do i need after market computer? Link to comment https://www.sau.com.au/forums/topic/55404-splitfire-coil-packs/#findComment-1083226 Share on other sites More sharing options...
Sinista32 Posted November 10, 2004 Share Posted November 10, 2004 Im Running 12psi - suffering the same problem both in my GTS-T and GTR both 93's. You could go a bosch external coil pack like I did on the GTS-T prior to selling. I then sufferd a problem with the Ignitor. I beleive 10-12 years and thats enough, time to replace. Correct on the age and also having them down the centre of the valley there is continuos heat in addition covered over by the plate. You will see alot of Skylines with the cover removed. Only problem removing is water/moister sitting. Very interested in the Splitfire. Perhaps a group buy from Nengun and we could get a heap at a more affordable price. Link to comment https://www.sau.com.au/forums/topic/55404-splitfire-coil-packs/#findComment-1083253 Share on other sites More sharing options...
nizmokid Posted November 10, 2004 Author Share Posted November 10, 2004 has anyone bought a set from Nengun on the web? Link to comment https://www.sau.com.au/forums/topic/55404-splitfire-coil-packs/#findComment-1083484 Share on other sites More sharing options...
nmcmahon83 Posted November 11, 2004 Share Posted November 11, 2004 how hard are these to install? Link to comment https://www.sau.com.au/forums/topic/55404-splitfire-coil-packs/#findComment-1083595 Share on other sites More sharing options...
Robo's Posted November 11, 2004 Share Posted November 11, 2004 There a drop in replacement from the standard ones. Link to comment https://www.sau.com.au/forums/topic/55404-splitfire-coil-packs/#findComment-1083609 Share on other sites More sharing options...
brett33 Posted November 11, 2004 Share Posted November 11, 2004 I had the same chronic missing problem too. Siliconed the bottom half of every coil pack. Problem solved. Saved a K. Link to comment https://www.sau.com.au/forums/topic/55404-splitfire-coil-packs/#findComment-1083621 Share on other sites More sharing options...
Robo's Posted November 11, 2004 Share Posted November 11, 2004 Where do you silicon, between the rubber boot and the base?? I need to do something with mine and if this is a short cut, i will try it Link to comment https://www.sau.com.au/forums/topic/55404-splitfire-coil-packs/#findComment-1083624 Share on other sites More sharing options...
KamikazeR33 Posted November 11, 2004 Share Posted November 11, 2004 unfortunately these wont work on a series 2 r33 without a few modifications as the splitfires dont have an ignitor pack in them Link to comment https://www.sau.com.au/forums/topic/55404-splitfire-coil-packs/#findComment-1083664 Share on other sites More sharing options...
nizmokid Posted November 11, 2004 Author Share Posted November 11, 2004 they also make them for the series 2 I was told? Link to comment https://www.sau.com.au/forums/topic/55404-splitfire-coil-packs/#findComment-1083665 Share on other sites More sharing options...
Duncan Posted November 11, 2004 Share Posted November 11, 2004 sure there are just 2 different part numbers Link to comment https://www.sau.com.au/forums/topic/55404-splitfire-coil-packs/#findComment-1083778 Share on other sites More sharing options...
nmcmahon83 Posted November 11, 2004 Share Posted November 11, 2004 how difficult are these to install? I'm a newby, best left to the pro's? Link to comment https://www.sau.com.au/forums/topic/55404-splitfire-coil-packs/#findComment-1083997 Share on other sites More sharing options...
JAPCAB Posted November 11, 2004 Share Posted November 11, 2004 Mate they are PISS easy. All u need is an allen key to undo the 8 allen bolts on the black nissan cover on the top of the engine. Remove the intake piping by undoing the hose clamps. Take off the black cover, then unclip each harness from the coil packs. Undo another few bolts, and the 2 coil pack assemblies come off. how difficult are these to install?I'm a newby, best left to the pro's? Link to comment https://www.sau.com.au/forums/topic/55404-splitfire-coil-packs/#findComment-1084072 Share on other sites More sharing options...
