Hi Guys,
I went to drive to work this morning and my damn front wipers werent working. I checked the fuses under the dash and it was ok. It sprays water and everything but no wiper movement. The rear wiper works ok as well. Any suggestions on what could be wrong. Its for a r33 gtst.
Thanks in advance
ak
https://www.sau.com.au/forums/topic/55407-front-wipers-not-working-help/
... i put higher rating fuses in 25 and was fixed.
Not usually a good idea. The fuse is there to protect everything. Putting a higher rated fuse increases the risk of damage before the fuse goes.
Why not just stick a 6" nail in there?
Replace it with a correct rating fuse.
Not only do you risk damage to the parts it supplies (ie: a small fault will lead to a big fault because the supply of power has not been cut), but also damage to wires and worse case may lead to a fire.
