Forget the numbers, All RB25 turbos have a groove in the compressor snout near the top of the blades. S1 as you said are steel and S2 a composite and black with single blades instead of duel. VG30 turbos have a wastegate outlet pipe mounted on the compressor cover. The trick is to get a VG30Ball Bearing Exhuast housing and bolt it on to a RB25 turbo. Some places have stacks of dead VG30's so can be done for free. It is a direct bolt on however be careful not to angle the housing when removing as the turbine housing as it can snap off the turbine reasonably easily(I know =). The best is to put it in a vice heat it up and it slids straight off. I have personally done this mod on an Rb20 and it made 15rwkw more with the same boost and less detonation. Exhuast note was noticably loader tho.
happy boostin
Yes to an extent, the R34 turbo's also have a alloy(silver) wheel. VG30 turbo's are almost the same but have a slightly smaller compressor and have the nipple on the compressor housing. If there is any VG30 or RB25 BB turbo's on the shelf that have a larger nut on the compressor grab one of them. The are pretty rare but can handle alot more boost before self destructing as they have a thicker shaft.
